turbo upgrade - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
turbo upgrade
Old 01-21-2013, 06:47 PM
davidherman89 davidherman89 is offline
davidherman89 is starting off with a positive reputation.
turbo upgrade
dos any one know what to upgrade my turbo to if i got banks six gun tuner with dpf out and banks air filter
Old 01-21-2013, 07:27 PM
senix's Avatar
senix senix is offline
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
Quote:
Turbo does need to be upgraded. It will will give you plenty of boost if you need it.
Old 01-21-2013, 07:54 PM
Well would you know what would make my truck over boost when I'm only giving 25% of gas
Old 01-21-2013, 07:58 PM
senix's Avatar
If you are throwing an overboost code...then set it back to stock power. What do you get then?
It could be that the high pressure turbo has an issue or your VGT is having an issue. It is not the banks.
Old 01-21-2013, 08:03 PM
Well its not throwing any codes
Old 01-21-2013, 08:07 PM
senix's Avatar
If you have the IQ and check for codes and there are none...then how often are you regening?
Has your mpgs dropped quite a bit?
Old 01-21-2013, 08:20 PM
No mpgs are the same and ok thanks man ill try these out
Old 01-21-2013, 08:23 PM
senix's Avatar
My high pressure turbo about a year ago was pushing out a little higher then I thought it should. I took it in and it was out of spec by 3.6 psi.
I had no codes either. Ford replaced it under warranty.
Old 01-21-2013, 08:25 PM
Oh ok thanks man thats what I was think maybe just buy a high pressure turbo to
Old 01-21-2013, 08:28 PM
senix's Avatar
if you are still less then 5 year/100K then it would be a warranty repair.
Old 01-21-2013, 08:31 PM
Old 01-21-2013, 08:32 PM
Ok thanks man
Old 01-21-2013, 09:53 PM
ATX F250 ATX F250 is offline
ATX F250 is starting off with a positive reputation.
That may be the weirdest thread I have ever read. Just saying
Old 01-21-2013, 11:46 PM
2x6 bulldog's Avatar
2x6 bulldog 2x6 bulldog is offline
2x6 bulldog is starting off with a positive reputation.
I did it last week did't work.i wouldn't recommend to anybody.
Old 01-25-2013, 01:50 PM
Ok so I did all that and I didn't get no code now when I'm not towing to don't over boost now when I get on it
banks 2nd gen upgrades? Red454sedgwick Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 8 05-27-2013 01:34 AM
'89 f450 turbo bcarless Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 26 05-26-2013 07:57 PM
38R and Wastegate? Pitcrw6 1999 - 2003 7.3L Power Stroke Diesel 5 09-08-2012 12:15 PM
Banks question. wgerson Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 14 11-12-2008 07:02 PM
Banks turbo upgrade bricot 1999 - 2003 7.3L Power Stroke Diesel 5 09-10-2002 08:59 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
