F450 Fuel Mileage - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis SPONSORED BY:
F450 Fuel Mileage
Old 01-21-2013, 05:22 PM
HAMMERDOWN103 HAMMERDOWN103 is offline
HAMMERDOWN103 is starting off with a positive reputation.
F450 Fuel Mileage
For those of you that have an F450, what do you get for fuel mileage? My dad has a 2010 F350 CC LB and gets around 11.5-12. I'm looking at a 450 to tow my 15k trailer. Don't want a pig but need a big truck to pull that trailer ....
Old 01-22-2013, 12:40 AM
2x6 bulldog's Avatar
2x6 bulldog 2x6 bulldog is offline
2x6 bulldog is starting off with a positive reputation.
I have the same truck and get the same mileage. I have on order a tuner and DPF delete pipe. I also run Opti Clean witch helps a little and is good for your injectors and fuel pumps.
The tuner will stop burning fuel in the DPF wasting it and make my engine run better, cleaner and longer burning less fuel. BTW I will be able to get 250 more horsepower if I want.
Old 01-22-2013, 02:37 PM
Yeah unfortunately I am in California so there is no chance of getting away with a dpf delete kit here .... And some tuners wont even ship here so I am stuck with moderate tunes at best. Mostly looking for a little power and a lot of mpg if I go the 450 route ....
Old 01-29-2013, 11:05 AM
redz284u's Avatar
redz284u redz284u is offline
redz284u is gaining momentum as a positive member of FTE.
I get 12-13 around town. 10 hauling my 5th wheel.
Old 01-31-2013, 04:53 PM
RTRF350's Avatar
RTRF350 RTRF350 is offline
RTRF350 is starting off with a positive reputation.
If you cannot get a DPF Delete then you are screwed on fuel mileage. Mine was getting 10-12 unloaded and when I pulled my 16,000# fiver I could get anywhere between 5-7. The fuel mileage on the 450 is really bad, especially if it has the 4.88 rearend gear. I have since deleted the DPF and now I am seeing 13-15 unloaded and I have not pulled the fiver yet with it so I do not know how that will be.
Old 01-31-2013, 06:04 PM
Glenn Jenne's Avatar
Glenn Jenne Glenn Jenne is offline
Glenn Jenne is gaining momentum as a positive member of FTE.Glenn Jenne is gaining momentum as a positive member of FTE.
I get 11-12 around town and 9-10 with my 14k fifth wheel behind me (488 gears). I would of course like to get better, but it is worth it to me because the truck pulls so well. Still completely stock. -Glenn
Old 01-31-2013, 11:19 PM
StanleyZ's Avatar
StanleyZ StanleyZ is offline
StanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to behold
You might want to consider an F350 DRW truck. It will tow 15,000 up a tree. My trailer goes 17500 and over when everything is on board. I towed for a year and a half with DPF on and climbed all the rockies without a problem. Now there is a trade off with the 350 as you can get a 4.10 rear axle or even a 3.73 and I think the 2009s and 10s had a 3.55 available but maybe not. With the 450 I think all you can get is the 4.88 which is a real fuel eater. So, you give up a little power and gain a little economy with each higher rear axle. Mine is a 4.30 and I got 7.5 to 9 towing. Didn't drive it enough to check non-towing mileage.
In addition to low fuel mileage the primary problem with the DPF technology is diluting the oil with diesel and the extra wear this causes. If you can't delete the mileage is what it is, but there are some things you can do with the DPF on to keep the dilution under control. I was doing OK with an oil management program that went like this: added a quick drain oil spigot. Changed oil and filter at 5000 miles. Between changes at each 1000 miles I would drain the oil down to one quart low and add a quart of fresh. It helped a lot as verified by oil analysis reports and cost $17 each oil change cycle. Hope this helps.
Old 02-01-2013, 12:31 AM
The 2008 F450 had two axle ratios from the factory. 4.30 and 4.88 in a Dana s110 rear end. That rear end is big and very heavy. One big advantage of the F450 is the bigger brakes front and rear. Getting it going is one thing stopping with a fully loaded trailer is another. I moved up from a F350 to a F450 and what a difference. I did lose a mile per gallon going from a 4.1 to a 4.3 rear but it was worth it. My old 99 F 350 was highly modified and had more hp than the stock 08 F450 but not for long. The 450 was more stable and sure stopped better.
Old 02-01-2013, 09:03 AM
StanleyZ's Avatar
I didn't know the 4.30 was even an option. I guess that would be a little more economical than the 4.88. I'm sure the 450 being a bigger platform feels more stable when towing. My trailer has brakes designed to stop it and they work well. I towed it with a short bed extended cab F250 for a year and stopping was never a problem. Towing was OK except for down hill curves where the trailer was always pushing and the ride was uncomfortable, maybe exciting would be a more accurate discription. The 7.3 with mods pulled it fine but the DRWs are just so much more comfortable. One factor to consider for 5th wheel towing is that when you get there and unhook you have to drive what you towed with. Driving the DRW 350 around tourist towns is enough of a pain, a 450 would be even worse. The point I was trying to make is that there are a number of options available and they all involve some level of compromise.
Old 02-01-2013, 10:39 PM
RTRF350's Avatar
Quote:
Actually, my 450 is much easier to drive in tight city areas than my old 350 was. The 450 has a much tighter turning radius than the 350 because of the wider front axle. My wife did not even like to drive the 350 because t was so hard to park. Now with the 450 she loves to drive it to town.
Old 02-02-2013, 07:58 PM
tgreening's Avatar
tgreening tgreening is offline
tgreening has a good reputation on FTE.tgreening has a good reputation on FTE.
Quote:
Ditto on the driveability. During the summer my 450 is my DD, when it's not towing the camper. I was unaware of the turning difference when I purchased it and was expecting the same as the '06 F350 I've got at work. Amazingly surprised to say the least.
I have the 4.30 axles, and I don't how some of you guys drive but when I drove it back from Texas I ran anywhere 65-75 and was averaging 13.5 till I took a left and headed into the mountains.
Deleted now running a 210 HP tune and fairly confident I could hit 17 mpg if I can stay out of the mountains. Towing my 16.5K camper I average around 8.5-9.0 normally, but did manage to do 10.5 once.
Admittedly that 17.0 isn't going to happen unless I stay at 65mph max, relatively flat terrain, and drive like that fuel money is coming out of MY pocket.
Old 02-03-2013, 04:52 PM
sunkawinyan's Avatar
sunkawinyan sunkawinyan is offline
sunkawinyan is starting off with a positive reputation.
SeaWolf
***REPLY***Just bought in Nov-2012 a used 1999 F450 7.3-liter auto transmission Lariat crew cab to pull CGWR of 29,000 lbs. Fuel Mileage thus far = close to 12 mpg running light. Just installed K&N air filter that boosted hp and added 1 additional mpg fuel efficiency = now 13 mpg. Next will install Cortex 1950 superchip and hope to gain additional fuel efficiency. Also use Amsoil products exclusively and hope to see engine efficiency (runs cooler) improve as a result of Amsoil products.
Quote:
Originally Posted by HAMMERDOWN103 View Post
For those of you that have an F450, what dconsumption. you get for fuel mileage? My dad has a 2010 F350 CC LB and gets around 11.5-12. I'm looking at a 450 to tow my 15k trailer. Don't want a pig but need a big truck to pull that trailer ....
Old 02-03-2013, 05:30 PM
Seawolf
I have the 4.56 rear end and love its turning ability I have not towed 31-foot MS 5er yet ... but in-city driving is great ...I am cautious about suitable Seattle parking space for truck is my only concern, but once parked, do not mind walking couple blocks to my destination.
Old 02-03-2013, 05:35 PM
StanleyZ's Avatar
Quote:
Seattle, the only place they have ever made me pay for two spaces to park my DRW in a pay lot. It was 6:30 PM and the place was nearly deserted, but I had to pay for two spaces or go elsewhere. Would have exercised the go elsewhere option but we were late for a dinner date.
Old 02-04-2013, 11:13 PM
a4t1rat's Avatar
a4t1rat a4t1rat is offline
a4t1rat is starting off with a positive reputation.
I have a 08 f450 I love the truck it is the ultimate for pulling. I drive mine daily also every day. It will out turn a f350 and out stop one as well I call it my 10,000 pound Porsche.. lol. There is alot of miss information about these trucks. As far as axle ratios you can get gear ratios from 3.50 on down to 5.13 and lower. I have a set of 4.88, 4.30, 4.10 and a set of 3.73's I am running the 4.10 now. and yes its a 4x4 so I have both sets complete with carriers. Mine is DPF deleted with a H&S tuner, cold air intake and EGR delete among other things.I can get 15-17 mpg crusing at 75-85, keep in mind speed limits here are 80 and most drivers will run 85-90. this is my second 08 f450 its a great truck but the stock gears are what will kill your mpg. I would not tow my trailer with anything else. Just the braking alone is worth it.
2015 F450 FUEL MILAGE choppereddie 6.7L Power Stroke Diesel 22 07-22-2015 12:19 PM
F-450 Super Duty differential ratio adept99 1999 to 2016 Super Duty 13 07-31-2011 10:47 PM
2008 F450 V10 C&C Gas Mileage? sammydiesel 1999 to 2016 Super Duty 2 03-27-2009 08:00 AM
F450 4.88 Gas Mileage nobull1 Modular V10 (6.8l) 21 11-30-2007 06:24 PM
More F450 questions mrxlh 1999 to 2016 Super Duty 4 09-19-2007 07:52 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
