351w oil pan what kind of sump? - Ford Truck Enthusiasts Forums
Old 01-21-2013, 03:43 PM
jrockdiddy's Avatar
jrockdiddy jrockdiddy is offline
jrockdiddy has a great reputation on FTE.jrockdiddy has a great reputation on FTE.jrockdiddy has a great reputation on FTE.jrockdiddy has a great reputation on FTE.jrockdiddy has a great reputation on FTE.jrockdiddy has a great reputation on FTE.
PUtting a heidts crossmember on next week, pulling the motor tomorrow. I believe i need a front sump oil pan. Do I need a different oil pickup tube or screen or something.?
not a good pic
Old 01-23-2013, 09:12 AM
Aarons54f100's Avatar
Aarons54f100 Aarons54f100 is offline
Aarons54f100 is gaining momentum as a positive member of FTE.Aarons54f100 is gaining momentum as a positive member of FTE.
With my Cleveland a rear sump was required. But assuming your motor mounts are already in place this could be tricky. A lot of people (including myself) move the cross member forward to center the wheels in the fenders. If you do need a rear sump you will need the corresponding pickup tube for that pan.
It is easier to install a member and then install the mounts based on where it needs to be around the member.
Old 01-23-2013, 10:02 AM
ben73058's Avatar
ben73058 ben73058 is offline
ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.
Hey Jrock,
You need a rear sump pan to get over that new
Heidt's IFS - not a front sump. You'll see once you try to install the engine
over that thing.
Ben in Austin
1950 F1
Old 01-23-2013, 11:43 AM
jrockdiddy's Avatar
Cool. Just ordered a ford racing rear sump that comes with its own pick up tube. Thx guys
what kind of flare is this? pic jrockdiddy 1948 - 1956 F1, F100 & Larger F-Series Trucks 14 03-21-2013 12:08 AM
OIl pan 351w mustang II jrockdiddy 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 01-22-2013 11:29 PM
Picture needed 223 oil pickup 52runner 1948 - 1956 F1, F100 & Larger F-Series Trucks 13 12-24-2011 03:10 PM
Rear sump oil pan? daves54 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 1 01-18-2010 08:11 PM
have 400 bronco pan - need front sump pan blu93gt 1966 - 1977 Early Broncos 2 08-10-2002 10:10 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
