Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 01-21-2013, 01:59 PM
Byrd.Dog's Avatar
Byrd.Dog Byrd.Dog is offline
Garage is empty, add now
Byrd.Dog is starting off with a positive reputation.
Looking for some part numbers & sources
I'm looking for parking brake cables, a parking brake lever(goes inside the drum & pushes pads out when parking brake is applied), and a speedo cable. Can't find any of this at Napa, O'Rielly's, etc. Found some stuff @ Dennis Carpenter Ford, but they don't have the lever, & don't specify if the parking brake cables or speedo cable will fit a 4x4(application is just listed as F100). Can anyone suggest any other sources for parts?
Thanks!
__________________
1960 F250 4x4 - 292, 4spd, 16,000 ORIGINAL miles
2000 F350 Powerstroke CCLB 4x4 - Tuner, Intake, Exhaust, Gauges, leveled on 35's
1998 Cummins QCSB 4x4 - stock
  #2 (permalink)
Old 01-21-2013, 07:52 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a good reputation on FTE.spurredon has a good reputation on FTE.
Have you tried Macs?
  #3 (permalink)
Old 01-21-2013, 07:53 PM
theodore/teddy's Avatar
theodore/teddy theodore/teddy is offline
theodore/teddy is gaining momentum as a positive member of FTE.
Birdog; On the cable, which do you need the cable from handle to the equalizer or from the equalizer to the drums. the two levers you need for inside the rear drums are
Right side B7TZ-2A637 and
left side B7TZ-2A638
The cable from equalizer to the drums is C0TZ-2A635
I did a google search for these numbers and found the cable and the left side lever but no right side.
I'm sure Bill will be along shortly to correct any mis-info on my part and he has a much better search source.
Good luck in your quest
Idaho is correct on the rear cable assembly I forgot the D on the end C0TZ-2A635D
__________________
1959 F250 4x4
Wally
  #4 (permalink)
Old 01-21-2013, 10:10 PM
idaho211 idaho211 is offline
idaho211 is starting off with a positive reputation.
Byrd.dog,
There are two parts to the parking brake cable. The part that starts from the pull lever is the same for any two wheel drive 3/4 ton and is available new at Dennis Carpenter. The second part that attaches to the rear wheels is one assembly and is specific to 4x4's and is longer.
For the 3/4 ton 4 wheel drive 59-60 number is C0TZ 2A635D rear assembly.
There are 2 available I see at Greensales Ford.
I couldn't find the lever or cross over links that activate the drum pad when I was looking for my 60 4x4. I found a used set from a 3/4 ton at a wrecking yard and you might have to look around.
The springs for the center link are still available at Greensales, get 1 per side and are C4UZ2A601A. You will need spring washers and U clips. Hope this helps.
  #5 (permalink)
Old 01-22-2013, 08:03 AM
Byrd.Dog's Avatar
Thanks guys!
__________________
  #6 (permalink)
Old 01-26-2013, 02:34 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
2013 Ford Escape
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
1960 F250 4WD
Quote:
Originally Posted by Byrd.Dog View Post
I'm looking for parking brake cables, a parking brake lever (inside drum, pushes shoes out when parking brake applied), and a speedo cable.
COTZ-2A635-D .. Rear Parking Brake Cable-143 1/2" long / Obsolete
Applications: 1959/60 F250 4WD only.
GREEN SALES CO. (not a Ford dealer) in Cincinnati OH has 1 = 800-543-4959.
CARPENTER NOS OBSOLETE PARTS (not a Ford dealer) in Concord NC has 3 = 800-476-9653 (Note: Listed as C0TZ).
B9TT-2853-L .. Front Parking Brake Cable-88 1/2" long / Obsolete
Applications: 1959/60 F100 2WD/4WD with 118" wheelbase (8' bed) / 1959/60 F250 2WD/4WD
GREEN SALES CO. has 1.
WESLEY OBSOLETE PARTS in Liberty KY has 1 = 606-787-5293.
Listed on page 18 of Carpenter's 1957/66 truck repro parts catalog. Download it or call DC and order the puppy, it's free.
B7TZ-2A637-A .. Right Parking Brake Lever / Obsolete
Applications: 1959/65 F250 2WD/4WD / 1966/72 F250 2WD/4WD ~ Use with 12 1/8" x 2" brakes.
CARPENTER NOS OBSOLETE PARTS has 1. (Note: Obsolete parts not listed in DC's repro parts catalogs).
HAVEN FORD in Haven KS has 1 = 620-465-2252 (Haven will probably be cheaper than DC).
B7TZ-2A638-A .. Left Parking Brake Lever / Obsolete
Applications same as B7TZ-2A637-A (Note: Some 1966/72 F250's have 12" x 2 1/2" brakes).
PARTS INTERNATIONAL in Farmers Branch TX has 1 = 888-727-0418.
GREEN SALES CO. has 13.
C3TZ-17260-A .. Speedometer Cable-109.12" long / Obsolete
Applications: 1959/62 F250 4WD with 3 & 4 M/T.
WESLEY OBSOLETE PARTS has 1.
NOS PARTS SOURCE in Olathe KS has 1 = 913-220-5746.
You know what I find amazing? I have Carpenter and etc repro parts catalogs and don't own an old Ford.
Y'all own these old Ford trucks, yet most of y'all do not have any repro parts catalog from anyone. Ridiculous!
And, most of y'all don't have this: 1957/63 Ford Truck Parts Catalog, available on a CD from hipoparts.com
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
2013 Escape SE FWD 2.0L Eco-Boost.
  #7 (permalink)
Old 02-06-2013, 09:21 AM
Byrd.Dog's Avatar
Thanks for all the help!! I located all the parts I was looking for between Green Sales & Dennis Carpenter Ford. Only problem is that it's been so long since I took the parking brake cables off, I don't remember exactly how they bolt back up to the undercarriage! Think I'm ok on the handle in the cab & bolting up the rear assy; just not 100% on the linkage where the front & rear cables hook together. Anyone have a diagram they'd be willing to share?
__________________
  #8 (permalink)
Old 02-06-2013, 06:11 PM
spurredon's Avatar
Did you read the last line from NumberDummy's post above? You could have all the pics you will ever need!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
