Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 01-20-2013, 10:03 PM
fordalltheway818 fordalltheway818 is offline
Garage is empty, add now
fordalltheway818 is starting off with a positive reputation.
Help Cluster
Hello guys. Well I got a 1960 F100 and im putting in a 2000 ford lighting motor in it. I already have the motor with tranny and wire harness and all that good stuff. The issue im having is how am i going to hook up the cluster with the new harness. Do they sell a kit that could go in the truck and wire up to harness or do i put in the lighting cluster in it? I would really appreciate it if guys can help out. Thanks
  #2 (permalink)
Old 01-22-2013, 09:27 AM
3414 3414 is offline
1960 Ford F-600
My Garage
3414 is gaining momentum as a positive member of FTE.
With that engine and transmission you might not have a place to connect the speedometer cable, the 2000 trucks used a pickup on the rear axle to drive the speedometer.
Someone might make an adaptor or input device to get you a mechanical connection if you want to use the old speedometer.
On the old gauges - they will work with the Lightning engine if you put compatible (old style) sending units in the engine.
It might be less work to adapt the gauges and speedometer from the Lightning cluster to the old cluster.
  #3 (permalink)
Old 01-22-2013, 10:02 AM
theodore/teddy's Avatar
theodore/teddy theodore/teddy is offline
theodore/teddy is starting off with a positive reputation.
fordalltheway818; welcome to the forum. not much help for you here, but I would like to follow your progress and we all like pictures.
__________________
Looking for an in bed spare tire mount for styleside fridge bed.
1959 F250 4x4
Wally
  #4 (permalink)
Old 01-23-2013, 09:37 PM
Thanks for the info i really apreciate it. I will post pic as soon as i start
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
