1972 ford f-250 throttle linkage
Green Sales shows 4 @ 1-800-543-4959
Bob Allen Ford (expensive usually) 1-913-381-2999
on
Here's the "dash A" part installed:
And here's the "Dash B" part installed:
The area circled in red is the difference between parts.
It looks like the "dash B" part could be used in place of the "dash A" part, but not neccessarily the other way around.
I don't understand why the Ford Engineers would include the extra lever arm on the "dash B" part if it isn't hooked up to anything.
on
So the older part has the extra arm and the newer part doesn't.
This makes me wonder if the older part is the "dash A" part, regardless of whether the truck is manual or automatic.
If this gets any more confusing, I'm going back to writing software.
1964/72 Ford Truck Parts Catalog / Illustration Section 97, Page 24 shows all the linkage in an exploded view.
Fordification has this parts catalog on their website (it's the CD version), or you can get your own CD from hipoparts.com
The usual problem lies with the bellcrank (7A185 in pic) that bolts to the left (drivers) side rear corner of the intake manifold that all the linkage attaches to.
The levers on the bellcrank have nylon bushings that wear causing the linkage to bind up. The bushings are not replaceable, so the bellcrank has to be replaced.
DOTZ-7A185-A .. Bellcrank / 1970/72 F100/350 360/390 w/a M/T / Obsolete ~ If this turns out to be the problem, 10 are available NOS
Does the 302 engine use a different bellcrank? Looking for the part # for one for a 71 F100 with manual transmission.
4RDLVR
02-15-2006 11:16 AM
runcrashboy
05-09-2004 10:55 AM
DuckRyder
05-06-2003 05:30 AM
