7.3L white smoke at start up - Ford Truck Enthusiasts Forums
Old 01-19-2013, 07:39 PM
rowekmr rowekmr is offline
rowekmr is gaining momentum as a positive member of FTE.rowekmr is gaining momentum as a positive member of FTE.
Hello
I came across a 00 Excursion with 200K miles from a dedicated diesel truck owner. He had it 9 months but wants to downsize.
On start up he says it produces white smoke for a few minutes and thinks it is either a O ring on a injector, glow plug or glow plug relay. What does white smoke at start up mean? He says it will do this when it isn't plugged up on a cold day otherwise there is no smoke. Is this something to worry about?
Old 01-19-2013, 08:02 PM
twg1966's Avatar
twg1966 twg1966 is offline
Trying to Gain Knowledge
twg1966 is a name known to alltwg1966 is a name known to alltwg1966 is a name known to alltwg1966 is a name known to alltwg1966 is a name known to alltwg1966 is a name known to all
It is likely that you aren't letting the glow plugs run the full time before starting and the fuel isn't completely burning up. You can add an LED to the GPR and let the plugs run fully before starting.
http://www.guzzle7pt3.com/s_gpr.php
Old 01-19-2013, 08:09 PM
tappit01's Avatar
tappit01 tappit01 is offline
tappit01 has a good reputation on FTE.tappit01 has a good reputation on FTE.
nothing really to worry about. new g p's cost about $80. bucks and a relay is about $40. easy to change out either. just do a test on them to see witch is bad.
greyish white smoke Cowboy9215 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 7 04-05-2015 09:08 PM
Problem with 7.3 Codycamp 1999 - 2003 7.3L Power Stroke Diesel 25 03-02-2015 10:02 AM
intermittent idle drop and white smoke 86351wHOsupercab 1999 - 2003 7.3L Power Stroke Diesel 13 01-15-2014 10:27 PM
white smoke on crank ? Glow plug? Guzzo 6.0L Power Stroke Diesel 8 12-08-2013 12:46 PM
Engine smokes white/blue start up and idle Baldormotorman 1999 - 2003 7.3L Power Stroke Diesel 21 08-15-2012 05:39 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
