3 Projects out of the way (DONE) - Ford Truck Enthusiasts Forums
Old 01-19-2013, 06:12 PM
tasboj's Avatar
tasboj tasboj is offline
tasboj is starting off with a positive reputation.
Finally got this 3 projects done,
3G alernator swap,
Electric fan,
Front sway bar.
Here are some pictures of the finish product, thanks to all you guys for the info and suggestions, let me know what you think thank again.
3G alternator swap.
Chevy S-10 power strip with cover
Electric Fan.
BMW Fan Switch High & Low
Front Sway Bar.
Need to find a nice radiator overflow tank.
Old 01-19-2013, 07:37 PM
HIO Silver's Avatar
HIO Silver HIO Silver is online now
HIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud of
Bravo! Bravo!
Take it for a spin yet with the new swaybar??... (no pun intended) . Tell us your impression on how different it feels...
Old 01-19-2013, 10:34 PM
tasboj's Avatar
Quote:
Originally Posted by HIO Silver View Post
Bravo! Bravo!
Take it for a spin yet with the new sway bar??... (no pun intended) . Tell us your impression on how different it feels...
Its day and night, the drive feels more solid especially when I turn,no more of the front corner digging in when I turn. Now I am looking for a rear bar so it can be a real solid ride for when I tow.But what a difference "I LIKE IT" also got all the front end done radius arm bushings,pivot bushing,tie rod ends,drag link and coil springs,got the alignment also,thank for the help to all of you
Thanks HIO for all the info and answer to my questions.
Old 01-19-2013, 11:03 PM
HIO Silver's Avatar
That's awesome... I'm jealous that you got some projects done... my Lo-buck bumpside build is on hold until I finish a remodel on one of my rental homes.
You're welcome... 'glad that you found my input helpful.
Old 01-19-2013, 11:33 PM
grinnergetter's Avatar
grinnergetter grinnergetter is offline
grinnergetter has a good reputation on FTE.grinnergetter has a good reputation on FTE.
Nice job...radiator bracket looks pretty sharp too.
Old 01-20-2013, 12:09 AM
tasboj's Avatar
Quote:
Thanks grinnergetter I made those out of 3"x 1.5"x 3/16" or 1/8" angle iron,The idea was to use the whole piece so I could cover the radiator core but it was to heavy and aluminum was to expensive for my pocket, so came out with this design which I liked how it came out,steal strong and looks like it belongs there at list to my opinion.
Old 01-20-2013, 12:49 AM
68cabby's Avatar
68cabby 68cabby is offline
68cabby is starting off with a positive reputation.
Now...where would one find a sway bar for one? I have a 68 with no ps and would that make any difference?
Old 01-20-2013, 01:42 AM
tasboj's Avatar
Quote:
I found my at the junk yard,I would suggest a google search for sway bar for your model truck.
And yes it dose make a deference not on the steering,but on the stability of the truck for turning and sudden moves.
PS or not you can steal install a sway bar.
Old 01-20-2013, 07:04 PM
70-360fe 70-360fe is offline
70-360fe is starting off with a positive reputation.
Looks great! I put j/y sways on front and rear awhile back and like the difference.
Is this a power strip? If so where did you get it, been looking for something like it. Thanks
Old 01-20-2013, 07:14 PM
Is that your fan controller? If so is it a hi - lo controller, just curious looks good.
Old 01-20-2013, 07:46 PM
HIO Silver's Avatar
It appears to be... I'm gonna look for one tomorrow:
Old 01-20-2013, 08:12 PM
tasboj's Avatar
Quote:
70-360fe yes its a power strip out of a S-10 its located on the driver side above wheel well in the engine compartment, this one comes with the cover like the one I show in the pic, and the fan controller is a high and low out of a Volvo with electric fan, some have it in the front above fan,others are located passenger side behind headlight low ,the controller info I found in a google search. hope this helps it is easy to install,the fan switch on my radiator shown on the pic is a high and low from a BMW located on the radiator passenger side if you have any more questions don't hesitate to ask. now before you guys rag on me for using Chevy parts or Volvo what ever works is aloud.
Search this in google.
Budget Dual Fan Controller Setup / Taurus Fan Setup - NastyZ28.
Old 01-20-2013, 08:34 PM
Quote:
Thanks for the info I will look into the strip next time I go to the junkyard. I pulled a fuse box to add extras a while back but did not like the looks of it when I got it home.
Ok I was actually looking at the temperature sensor (feel dumb now) not the controller. Looks nice and clean, I have the usual sensors everbody gets from autozone/advance auto. Did you have to weld a housing into the rad. for the sensor? Do you know the temperature Hi Lo settings of the sensor. Just curious has a nice clean look. Thanks.
Old 01-20-2013, 08:46 PM
HIO Silver's Avatar
if you have any more questions don't hesitate to ask. now before you guys rag on me for using Chevy parts or Volvo what ever works is allowed.
.. thanks for citing the donors. The hunt begins!
And about using off-brand parts.. no ragging from me as there are GM parts on my Dentside.
Here's a funny story... ever since restified my 68 Mustang, the mechanical fan had a wobble because the 200-cube inline six came out of another wrecked 68 (Rear ended by a concrete mixer and yjrm pushed through a concrete block wall!!). I tried and tried to reset the blade pitch without much success. It had wobbled enough such that this is my third water pump. 'Couldn't use an off-the-shelf fan because of too much pitch with not enough room btwn the PS drive belt and the 3-row radiator. I searched and searched for an OEM fan for 16 years without any luck.
Last year, I was walking around the salvage yard and there was an old Dodge fire truck.... circa 1950s. Out of curiosity I looked at it and lo and behold it had a fan with a shallow pitch!!! Woohooo!!!! I ended up cutting off one inch off each blade and re-drilled the hub holes... PERFECT!!!!!!!
Old 01-20-2013, 09:04 PM
tasboj's Avatar
Your welcome After all the help you offered, now its my turn to contribute.70-360fe look at my last post before this one I posted the link I searched it will tell you the temp the switch operates at
1978 F150 5.3 LM7 Swap Rossta86 Engine Swaps 44 12-27-2016 07:33 PM
2007 mountaineer explorer deployable power running board vipersinu2 Explorer, Sport Trac, Mountaineer & Aviator 17 11-30-2016 08:21 AM
48' F1 PROGRESS BUILD !! cashy52 1948 - 1956 F1, F100 & Larger F-Series Trucks 45 09-07-2015 10:35 AM
My 53 build JRC99408 1948 - 1956 F1, F100 & Larger F-Series Trucks 44 08-23-2013 07:33 AM
Been MIA.... But I'm Back! (Truck Pics!) Robbgt 1994.5 - 1997 7.3L Power Stroke Diesel 30 02-15-2010 01:29 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
