1991 F-150 5.8 starts, dies then won't restart - Ford Truck Enthusiasts Forums
Old 01-19-2013, 04:36 PM
test tech test tech is offline
test tech is starting off with a positive reputation.
I hamy truck runnng. It died and won,t restart. Got fuel pressure bt no spark. Tested the coil it,s good, the relays, module and dist are all new. Still have no spark. Occasionally after it sits when the key is turned on the check engine lamp comes on during the self test, at that time it will start die in seconds won,t restart and no lamp. I have power at all the fusible links and at the relays and the coil. Any ideas?
93 F350 460 died won't start HELP horseminister 1987 - 1996 F150 & Larger F-Series Trucks 12 10-15-2016 09:06 AM
88 f250 randomly dying/not starting bk1200r 1987 - 1996 F150 & Larger F-Series Trucks 1 08-17-2016 10:31 PM
91 died at stop sign cliftonsinclair 1987 - 1996 F150 & Larger F-Series Trucks 10 07-20-2012 11:58 PM
88 F150 lost power then died now won't start mousey831 1987 - 1996 F150 & Larger F-Series Trucks 4 03-26-2011 10:28 PM
88f250 cranks, but won't start montangrunt 1987 - 1996 F150 & Larger F-Series Trucks 21 05-13-2004 04:15 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
