Tracking down a short!! Battery going dead!
Hey guys. I have a short somewhere and was hoping you guys can help trace it down. My battery keeps going dead every day and a half if I dont start it. I was told to pull the negative wire off of the battery terminal and put a 12v light tester between the wire and the battery. If it lights up, there is a short.
Well, I did that and there is a short. I pulled each fuse until the light went out to narrow down my hunt. It is fuse #110 I believe in the power distribution box under the hood. I pull that fuse, and the light goes out.
In the manual it says it is the trailer tow electric brake. When the fuse is pulled, my dome lights, door chime, radio, and brake lights dont work. I am a little confused. I messed with everything trying to find the short. No luck. Do you guys have any suggestions?
Ive unplugged the radio, unplugged my brake controller, checked my bulbs for my brake lights.......no luck!!
Check your radio, they will often do that. Always the first place I'd check when the battery goes dead after a couple of days but has no problems when driven daily. Although I've only ever seen it in cars with CD players.
Guess I should have read more closely you've already eliminated the radio
It didnt sound right to me either. I did just double check it, the cover for the distribution box under the hood is easy to miss read. Its fuse #105 which is the Junction Box Battery Feed. Not sure where to go to find the cause!! Any other tricks to narrow down a short??
F105 is the main feed to the sub-panel under the dash.
When testing for parasitic draw, you do need to give the battery timer in the GEM module 40 minutes to time out before accepting a reading of current draw as accurate.
Repeat the previous test using an ammeter and pulling the fuses in the under-dash fusebox.
Also make sure none of your overhead lights, under hood light, etc. are activated or on. Say if the door is ajar or the hood is open? make sure all your doors are closed and the hood switch is depressed when testing.
These will give you a false short reading and light up the tester with the method you are using to test.
elmozw1
1997 - 2003 F150
02-05-2008 07:39 AM
