99 F-250 stalls while accelerating - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 01-19-2013, 01:00 PM
CuNmUdF250's Avatar
CuNmUdF250 CuNmUdF250 is offline
CuNmUdF250 has a great reputation on FTE.CuNmUdF250 has a great reputation on FTE.CuNmUdF250 has a great reputation on FTE.CuNmUdF250 has a great reputation on FTE.CuNmUdF250 has a great reputation on FTE.
need more info...gas or diesel...mine had that problem it was one of the first symptoms of my fuel pump dying
Old 01-19-2013, 01:40 PM
Rick_l Rick_l is offline
Rick_l is starting off with a positive reputation.
Gas. Just changed my fuel pump 8-9 months ago. It doesn't start when first start driving truck. But starts when I try to accelerate onto the freeway. Could it be the throttle body.
Old 01-19-2013, 02:06 PM
CuNmUdF250's Avatar
did you put on a new fuel filter as well...so you saying it stumbles when hard accelerating like on ramp merging or passing
Old 01-19-2013, 02:14 PM
Yes, new filter and new pump. Even when I try to just go 3000 rpm at around 40 it doesn't really stumble it stalls, almost like what running out of gas feels like.
Old 01-19-2013, 02:29 PM
CuNmUdF250's Avatar
really sounds like its not getting enough gas...I`d look to do a fuel pressure test...get the test tool and you can hook it to a valve right on top of fuel rail near back on passenger side rail think 28-44 is normal if I recall
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
