Water pump / fan wobble normal?
I have a strange jingle coming from the Excursion. It's loudest directly in front of the fan. So I figured out how to get the fan cowl high enough to see the fan and clutch. Everything seems fine, but when its running there is a small wobble. Doesn't seem too bad, but it is only idling. So, is it normal to have any wobble, or is my pump heading south? My fan wires are still in tact so its not too bad. Seems a little early at 81k but maybe that's normal.
That's the key word. Wobble means out of balance which means it'll only get worse till it takes something else out with it.
Will do, I'm ok for a week or two, but I'll get it done. There is at most 1/8" wobble, just enough to see. Otherwise it would have eaten the wire harness for lunch. Once I noticed the fan I looked at the clutch and I can see it moving very slightly. That said, I'm not going to push my luck.
If this is the cause of my jingling noise, it's been like this for about a year. If not, I'll have good access to the pulleys and idlers to find it.
One thing it could be is the fan blade hub coming apart. If this is what is going on you really need to deal with it NOW.
When they coma loose the fan will bounce around taking a lot of things with it. Right now it only sounds a little loose.
Park it in as far as you can and put a tarp up to keep the air from moving as much as you can. USe a heat lamp to
keep your tools warm. The warming of the tools will help a lot. I had an old 1988 Ranger break a fan from the hub
I got lucky that it did not go into the radiator and make a hole.
Take the tension off the belt and see how much wobble is in the water pump and fan. If the fan moves and
the pump shaft sems stable then you have a place to start looking.
This is a case of "Pay Me Now Or Pay Me Later" Later is always more $$.
Sean
Sean
We're heading to sub-zero highs so I don't think I'll look at it in the next few days. Bad things happen to plastic parts at those temps. I really like that heat lamp idea. I usually try to put the tools in front of the bullet heater, but they can get hot, LOL. Yesterday was over 30 and I it sure was nice to not have to mess with heat or gloves. To really get a good look at it I'll need to pull the whole shroud. I agree there isn't much movement, but it is probably starting to go. Unless something is up with the clutch. Either way I need to pull it apart to look.
