1960 F100 small cab window to big window
OK, I am finally taking out my truck project that has been sitting in my garage for a year. It is a small window cab F100 and I want to know if there is a way to make it into a big window cab. The guy I bought it from gave me extra roof with back window part of cab. I have found a Ch**y site that shows out to make the replacement, but nothing for Ford. Can it be done??? or do I just stick with my small window cab? I hope this made sense. Thanks for any info.
It is the same principle if it is Ford or Chevy.(that probably opened a can of worms) The main concern I would have is to make sure you brace the cab. Weld in braces before you cut anything. I would also keep the doors on so the cab does not shift. That way you can check and double check to make sure it's still lined up!
Another thing to consider the time and money involved in doing a conversion. Maybe just get another rust free cab? It just depends the shape of your cab. And how far are you going with the truck. A full resto? And also do you have tools and garage space to do it. Just some things to take into consideration.
I've seen the replacement whole rear cab sections for chevy but I haven't found one for ford yet.... And just an easy splice in...
http://www.amazon.com/1955-59-Chevy-.../dp/B0042ZZO2S
Iv'e been kicking the big window upgrade idea around for my 59 F100 also. If I do this, I would do the whole roof and entire back of cab so the only welding would be at the top of the front window pillars and the back of the floor pan, under the fuel tank. Does this sound reasonable? My floor pan and firewall are in good shape with no major holes, but my roof is rotted above the front window and the back of the cab has holes in the bottom corners so that's the basis of my idea.
I did this about 15 years ago but had to use the bottom of the small window car. I cut the roof of the big window below the window opening and through the windshield posts. Would have been much easier if I could have used the complete back and if I had a wire feed at the time. Still worked out pretty good. Just remember to brace the part on the frame so it will stay in place. Hardest part for me was getting started. Just take plenty of measurements and don't get in a hurry. Good luck.
BullDog58
03-06-2017 03:55 PM
mysocks4
09-27-2008 01:26 PM
FE 27s
12-12-2004 02:17 AM
