97 f-150 4 wheel drive don't work
Here's what I'm dealing with. Got in my truck put it in gear and nothing. Thought my trans went out well to make a long storie short the motor on the transfer case is not shifting its stuck inbetween 2 high and 4 high replaced the motor its still doing it. So I have to unplug the motor and manualy put it In 2 wheel drive. . Any advice would be great....
Yes it turns thats how I change it from 2 high to 4 high, my light on the dash don't work either. Lights up when I start so I know it works. No matter where I turn the dial 2 high 4 high 4 low nothing happens. I have to unplug the motor on the transfer case to keep it in gear, if not it jumps inbetween gears. So confused. Thanks for the reply..
There's no way to "turn the dial" on my automatic '98 4X4 b/c it has the big floor mounted shift lever.
However it does have a solenoid on the front axle that kicks the 4WD in & out via the front differential. Have read that this shift mechanism is prone to sticking, rendering truck incapable of engaging front axle.
lamp210
12-14-2006 06:01 PM
Kwikkordead
49
07-16-2006 11:47 PM
