1977.5 lowboy auxiliary gas tank? - Ford Truck Enthusiasts Forums
Old 01-18-2013, 08:31 PM
1967 Turbo 6.9 1967 Turbo 6.9 is offline
1967 Turbo 6.9 is starting off with a positive reputation.
I've done a few search's and not found My answer.
Did the 4x4 trucks use a smaller auxiliary gas tank or was it mounted farther back?
Old 01-19-2013, 06:16 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
1977 F250 4WD (not a High Boy) auxillary gas tank.
Quote:
Originally Posted by 1967 Turbo 6.9 View Post
I've done a few search's and not found My answer. Did the 4x4 trucks use a smaller auxiliary gas tank or was it mounted farther back?
D7TZ-9002-C .. Mid-Ship Plastic Fuel Tank / 24.8 gallon capacity / Use with Evaporative Emission.
1977 F250 4WD w/133" wheelbase from serial number Y40,001 / 1978 F150/250 4WD w/133" wheelbase / 1979 F150/350 4WD w/133" wheelbase.
D7TZ-9002-D .. Mid-Ship Plastic Fuel Tank / 26.3 gallon capacity / Use without Evaporative Emission.
1977 F250 4WD w/133" wheelbase from serial number Y40,001 / 1978 F150/250 4WD w/133" wheelbase.
1977/78 4WD Crew Cabs used different mid-ship tanks. 1977/79 4WD Crew Cabs were also available with aft axle tanks.
Old 01-19-2013, 10:06 AM
I did find a photo of one
Auxiliary Tank dmyboat 1973 - 1979 F-100 & Larger F-Series Trucks 1 04-11-2015 12:54 AM
auxiliary gas tank old farmer Explorer, Sport Trac, Mountaineer & Aviator 0 03-15-2015 12:15 AM
Auxiliary or bigger tank needed Dogmann 1999 to 2016 Super Duty 12 01-28-2014 08:38 AM
two gas tanks Elliesgrandma 1973 - 1979 F-100 & Larger F-Series Trucks 4 08-12-2012 08:24 PM
Auxiliary fuel tank in V10 SuperDuty??? djpahan 1999 to 2016 Super Duty 7 07-25-2011 04:05 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
