Highboy Rear Fuel Tanks - Ford Truck Enthusiasts Forums
Old 01-18-2013, 04:12 PM
TrippingCobras TrippingCobras is offline
TrippingCobras is starting off with a positive reputation.
I am in the middle of a restoration of my 1977 F250 highboy and will need a new fuel tank. I have seen all of the work arounds and every one of them required custom fabrication, whether it be to the truck or the tank.
The primary design challenge is a result of the location of the cross member between the shackles on the rear frame.
My intent is to break the cycle and have a bolt in kit made and availablefrom a retailer.
READ THIS!
My question goes to all of the truck owners who still have a gas tank in their cabs due to this issue. If I can get a company to build a kit, how many of you would seriously be willing to purchase one?
Old 01-18-2013, 05:21 PM
PA74F250's Avatar
PA74F250 PA74F250 is offline
PA74F250 is starting off with a positive reputation.
I'm pretty sure some had a aux rear fuel tank from the factory so there's your bolt in kit.
Old 01-18-2013, 05:22 PM
PA74F250's Avatar
Old 01-18-2013, 05:27 PM
montana_highboy montana_highboy is offline
montana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud of
Quote:
Negative, highboys never came factory with anything other than the in-cab tank...
Only other option at the time were aftermarket saddle tanks.
Old 01-18-2013, 05:32 PM
Absolutely correct. I have done plenty of digging, there are no kits available. I just need to know how many people are interested.
Old 01-18-2013, 05:57 PM
PA74F250's Avatar
That's what I thought. However the truck I'm working is a early 77 F250 Hb and has been owned by my buddies dad since practically day 1 and was completely orig and it has the bed just like the one linked from eBay. What's up with that?
Old 01-18-2013, 06:23 PM
mikeo0o0o0's Avatar
mikeo0o0o0 mikeo0o0o0 is offline
mikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud of
Highboys used the same bed as 2WD (mounting holes are on a narrower spacing) but had a factory installed block off plate to cover the fuel filler.
Old 01-18-2013, 06:28 PM
PA74F250's Avatar
Quote:
Interesting
Old 01-18-2013, 06:35 PM
73-76 highboys had the round block off plate, or 'plug' if you will, 77's had the square fuel door, though it too led to nowhere, it was just a dummy door.
Old 01-18-2013, 06:49 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
73-76 highboys had the round block off plate, or 'plug' if you will.
D3TZ-9080-A .. Fuel Tank Filler Cover-Approx 4" round (steel) / Use to cover hole when mid-ship fuel tank isn't used.
1973/76 F250 4WD Regular & Crew Cabs / 4 available NOS unless you include the 22 that Collectors claim they have.
PA74F250: 1973/76 Styleside Beds have exposed fuel caps, 1977/79's have fuel doors.
33 1/2" distance between the inner frame rails behind the cab: 1973/77 F250 4WD (High Boys) / 1973/79 F350 Cab & Chassis / 1973/79 F350's on the 140" wheelbase.
All other 1973/79 F100/350's have 37 1/2" rear frame rails.
Old 01-18-2013, 07:59 PM
bucks77ford's Avatar
bucks77ford bucks77ford is offline
bucks77ford has a very good reputation on FTE.bucks77ford has a very good reputation on FTE.bucks77ford has a very good reputation on FTE.bucks77ford has a very good reputation on FTE.
There is a more or less bolt in tank made. It's expensive, but works. I have one.
AeroTanks - Ford 1028
Old 01-18-2013, 08:25 PM
Buck, you yourself complained about the price and fitment of that tank. If these tanks were stamped or made of plastic they would be half the cost.
Still waiting for a number of people.
Old 01-18-2013, 08:46 PM
Ya, I wasn't impressed with the filler neck placement which was too low and I had to modify it a bit and for over $400, it should have fit like a glove. It would be nice if a company would make something for much less with no modifications necessary. I was just pointing out that a bolt in tank does exist. The filler neck issues withe mine could have been a defect on my tank I don't know.
Old 01-19-2013, 08:03 AM
teds74ford's Avatar
teds74ford teds74ford is offline
teds74ford has a good reputation on FTE.teds74ford has a good reputation on FTE.teds74ford has a good reputation on FTE.
There was a thread a while ago about using a mid 80s cab-n-chassis tank. It was something like 86 with a 6.9 diesel, but I can't find the thread.
Does anybody know/remember this?
Old 01-19-2013, 09:07 AM
RunninD's Avatar
RunninD RunninD is offline
RunninD is gaining momentum as a positive member of FTE.
I did that with my truck. it was an 83 diesel f350 not sure if it was a cab n chassis, but it was a poly tank, I used the original straps to hold it up, and a second set to hold it down. I did use a 2" piece of square tube to form another cross member for the front of the tank, making sure to clearance the rear diff.
This is the only picture I have though, and it wasn't hooked up yet. http://i1101.photobucket.com/albums/...kfromabove.jpg
I wound up cutting the straps and shortening them, and then went back and re-bent the others to fit. I'm looking at going back in and putting in a skid plate off of a bronco to hold the tank up from the bottom.
New Member with a old truck... Lord Vokk New Member Introductions 4 06-02-2016 06:50 PM
BATTERY MAINTENANCE ? What you say! Thomas White 1999 - 2003 7.3L Power Stroke Diesel 4 07-11-2015 01:25 PM
Will “F 151” on my 78 Ford F 150 Title get me some grace at Emissions in Maricopa County, Arizona? Ira Brown 1973 - 1979 F-100 & Larger F-Series Trucks 8 12-19-2014 11:00 AM
Trouble Shooting Challenge - Logic Help Appreciated! Grinder Man 1997-2006 Expedition & Navigator 14 10-10-2014 09:35 AM
Transmission wire harness HELP! charon61285 1999 to 2016 Super Duty 0 04-10-2014 01:21 PM
Tags
fuel, gas, highboy, tank
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
