Highboy Rear Fuel Tanks
Old 02-16-2013, 08:36 AM
lafermedavid's Avatar
lafermedavid
lafermedavid is offline
HB tank
I need a tank$
  #32
Old 02-18-2013, 01:24 PM
daningraham's Avatar
daningraham
daningraham is offline
I am messing with this issue right now as I found a great 78' bed with the rear fill door that I modified to fit on my 74' and would like nothing more than to dump the tank in the cab. I would be in.
  #33
Old 02-18-2013, 02:01 PM
bucks77ford's Avatar
bucks77ford
bucks77ford is offline
Also remember, the Bronco II tanks fit between the rails. The rear crossmember must be moved back a little bit and some angle iron or whatever placed forward to mount some tank straps. It's a smaller tank, but not much smaller if any than the in cab tank. For me, I just wanted a bigger tank or I might have gone that route.
  #34
Old 02-18-2013, 02:12 PM
daningraham
Will the Bronco II tank fit between the rails on the 74'? Not sure if your 77' is the narrow or wider ones.
  #35
Old 02-18-2013, 02:18 PM
bucks77ford
Yep, mine also has the narrow frame rail. Here is a pic (courtesy of armstrongfordtrucks I think) that I had saved for reference showing a bronco II tank in a highboy.
  #36
Old 02-18-2013, 02:22 PM
daningraham
Perfect, thanks. I see that BG has a 33 gallon Bronco II tank as an option on their site, I wonder if I can get that wedged in there. Got a class 4 hitch to deal with too. Thanks for the info.
  #37
Old 02-18-2013, 02:33 PM
daningraham
Based on the pic it looks like the 23 gallon option at BG that fits a 1985-1990. Do you happen to know if that is the one? Doesn't look like any of the others.
  #38
Old 02-18-2013, 04:20 PM
bucks77ford
The one in the pic is out of an 84 Bronco II. Here is a link to armstrongfordtrucks gallery pic and what he did.
https://www.ford-trucks.com/user_gal...150642&width=0
I haven't seen him around posting much lately in this forum. Maybe he will chime in or if anyone else has done this will.
  #39
Old 02-18-2013, 04:41 PM
ChaseTruck754's Avatar
ChaseTruck754
ChaseTruck754 is offline
If I remember right the STOCK BII tank was 23 gal - so even in stock form it's more capacity than the stock, in-cab tank on these things.
  #40
Old 02-18-2013, 05:28 PM
bucks77ford
Ya, i did not realize that those bronco II tanks were 23 gals, so putting in one of those would be an upgrade.
Now if I could come up with a good way to put in a saddle tanks of some sort on mine. I have an open fuel door on my bed.
  #41
Old 04-02-2013, 10:21 AM
elkarcher1716's Avatar
elkarcher1716
elkarcher1716 is offline
Anything more come of this? I got a quote yesterday for 2300 SS tank and 1500 Aluminum. Way out of my league. I might be going the cheaper route and getting a bronco II tank. Let me know if anything new has surfaced.
  #42
Old 04-02-2013, 06:08 PM
ChaseTruck754
Dang - at that price I'd consider making another one of these for someone. As you said though - way outa most people's price range. I wouldn't pay that much! Heck, I'm too cheap to pay even $600 so I made my own & spent way too much time on it.
Almost done though! I'm currently messing with the fill neck. That is if I could ever get any time in the shop
  #43
Old 04-02-2013, 09:25 PM
elkarcher1716
Ya i told them to keep the SS. I was not going to pay that much. 600 is also way to much for me. I am going to get one from a bronco II and go with that.
  #44
Old 04-02-2013, 09:39 PM
montana_highboy's Avatar
montana_highboy
montana_highboy is offline
If i'm not mistaken the Bronco II tanks are available in both poly and steel.
  #45
Old 04-03-2013, 10:27 AM
elkarcher1716
thanks montana, I will have to search for the steel one. Really dont want to put a poly tank in if i dont have to.
Quick Reply: Highboy Rear Fuel Tanks
