Highboy Rear Fuel Tanks - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 02-16-2013, 09:36 AM
lafermedavid lafermedavid is offline
lafermedavid is gaining momentum as a positive member of FTE.lafermedavid is gaining momentum as a positive member of FTE.
HB tank
I need a tank$
  #32
Old 02-18-2013, 02:24 PM
daningraham's Avatar
daningraham daningraham is offline
daningraham is starting off with a positive reputation.
I am messing with this issue right now as I found a great 78' bed with the rear fill door that I modified to fit on my 74' and would like nothing more than to dump the tank in the cab. I would be in.
  #33
Old 02-18-2013, 03:01 PM
bucks77ford's Avatar
bucks77ford bucks77ford is offline
bucks77ford has a very good reputation on FTE.bucks77ford has a very good reputation on FTE.bucks77ford has a very good reputation on FTE.bucks77ford has a very good reputation on FTE.
Also remember, the Bronco II tanks fit between the rails. The rear crossmember must be moved back a little bit and some angle iron or whatever placed forward to mount some tank straps. It's a smaller tank, but not much smaller if any than the in cab tank. For me, I just wanted a bigger tank or I might have gone that route.
  #34
Old 02-18-2013, 03:12 PM
Quote:
Will the Bronco II tank fit between the rails on the 74'? Not sure if your 77' is the narrow or wider ones.
  #35
Old 02-18-2013, 03:18 PM
Quote:
Yep, mine also has the narrow frame rail. Here is a pic (courtesy of armstrongfordtrucks I think) that I had saved for reference showing a bronco II tank in a highboy.
  #36
Old 02-18-2013, 03:22 PM
Perfect, thanks. I see that BG has a 33 gallon Bronco II tank as an option on their site, I wonder if I can get that wedged in there. Got a class 4 hitch to deal with too. Thanks for the info.
  #37
Old 02-18-2013, 03:33 PM
Based on the pic it looks like the 23 gallon option at BG that fits a 1985-1990. Do you happen to know if that is the one? Doesn't look like any of the others.
  #38
Old 02-18-2013, 05:20 PM
The one in the pic is out of an 84 Bronco II. Here is a link to armstrongfordtrucks gallery pic and what he did.
http://www.ford-trucks.com/user_gall...150642&width=0
I haven't seen him around posting much lately in this forum. Maybe he will chime in or if anyone else has done this will.
  #39
Old 02-18-2013, 05:41 PM
ChaseTruck754's Avatar
ChaseTruck754 ChaseTruck754 is offline
ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.
If I remember right the STOCK BII tank was 23 gal - so even in stock form it's more capacity than the stock, in-cab tank on these things.
  #40
Old 02-18-2013, 06:28 PM
Quote:
Ya, i did not realize that those bronco II tanks were 23 gals, so putting in one of those would be an upgrade.
Now if I could come up with a good way to put in a saddle tanks of some sort on mine. I have an open fuel door on my bed.
  #41
Old 04-02-2013, 11:21 AM
elkarcher1716 elkarcher1716 is offline
elkarcher1716 is starting off with a positive reputation.
Anything more come of this? I got a quote yesterday for 2300 SS tank and 1500 Aluminum. Way out of my league. I might be going the cheaper route and getting a bronco II tank. Let me know if anything new has surfaced.
  #42
Old 04-02-2013, 07:08 PM
Dang - at that price I'd consider making another one of these for someone. As you said though - way outa most people's price range. I wouldn't pay that much! Heck, I'm too cheap to pay even $600 so I made my own & spent way too much time on it.
Almost done though! I'm currently messing with the fill neck. That is if I could ever get any time in the shop
  #43
Old 04-02-2013, 10:25 PM
Ya i told them to keep the SS. I was not going to pay that much. 600 is also way to much for me. I am going to get one from a bronco II and go with that.
  #44
Old 04-02-2013, 10:39 PM
montana_highboy montana_highboy is offline
montana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud of
Quote:
If i'm not mistaken the Bronco II tanks are available in both poly and steel.
  #45
Old 04-03-2013, 11:27 AM
thanks montana, I will have to search for the steel one. Really dont want to put a poly tank in if i dont have to.
New Member with a old truck... Lord Vokk New Member Introductions 4 06-02-2016 07:50 PM
BATTERY MAINTENANCE ? What you say! Thomas White 1999 - 2003 7.3L Power Stroke Diesel 4 07-11-2015 02:25 PM
AOD experts please help...rebuilt tranny Flintknapper Clutch, Transmission, Differential, Axle & Transfer Case 17 02-18-2015 09:00 PM
1966 f100 door tag decode request plum bob 1961 - 1966 F-100 & Larger F-Series Trucks 1 02-10-2015 08:17 PM
89 F250 351W no start problem tjc transport 1987 - 1996 F150 & Larger F-Series Trucks 4 10-30-2007 08:04 PM
Tags
fuel, gas, highboy, tank
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
