Instrument Cluster - Ford Truck Enthusiasts Forums
Instrument Cluster
Old 01-18-2013, 03:16 PM
crzrlou crzrlou is offline
crzrlou is starting off with a positive reputation.
Question Instrument Cluster
I have a 2003 F150 4x4 and I need to replace the instrument cluster. I am going to replace it with a used one. There are a lot of them on ebay. Does any one know if I have to have that exact year model of cluster for it to work right or can I replace it with one from a different year?? Thanks for any info
Old 01-18-2013, 03:38 PM
Bluegrass 7 Bluegrass 7 is offline
Bluegrass 7 has a very good reputation on FTE.Bluegrass 7 has a very good reputation on FTE.Bluegrass 7 has a very good reputation on FTE.
You will need to take the truck to a dealer for reprograming along with 2 keys.
The dash 'marrys' the PCM for PATS use and key programming.
If this is not done the motor will never be able to be started.
As for difference between 02 and 03, I would think no unless it's out of some other model than an F150..
Good luck.
As for difference between 02 and 03, I would think no.
Good luck.
Old 01-22-2013, 01:36 AM
jlkhvac jlkhvac is offline
jlkhvac is starting off with a positive reputation.
I'm not sure what exactly is wrong with yours but the odometer on mine keeps going blank from time to time but I found some very detailed videos on youtube that show you step by step how to fix the problem I'm having. Your issue may be different than mine but if it's the same I hope this helps.
Instrument cluster exchange genevanvoorst 1987 - 1996 F150 & Larger F-Series Trucks 5 08-26-2014 05:56 AM
'95 Instrument Cluster Swap Questions Nathan Plemons 1987 - 1996 F150 & Larger F-Series Trucks 7 06-14-2013 01:56 PM
04 Instrument Cluster replacement jdecker 1997-2006 Expedition & Navigator 0 11-23-2011 05:07 PM
Swapping out an instrument cluster in '78 F-150....Have a question. bhami8287 1973 - 1979 F-100 & Larger F-Series Trucks 8 11-10-2009 09:53 AM
instrument cluster replacement? ColtM4 1999 to 2016 Super Duty 4 02-05-2004 02:53 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
