Dually Conversion
Dually conversion
Let me start from the beginning, I have a 1995 F-250 5.8L and installing a 7.5L miked/balanced. Have to up grade my ZF transmission which I have. A friend got me a 1996 F-350 w/7.5L but I am going to just use the ZF trans, Drive line and the rear end is the dually I was talking about. I will be pulling a 9,000 ibs Travel Trailer.
on
but the question still remains.there are two f350's you see.just like there are two f250's.
f250 LD (kinda like a heavy half ton is all really) -pre 1992 (and oddly one more time in 1997) - not an f250 worth a dually convert.
f250 HD (f350 pickup platform)
f350 pickup (f250hd platform)
f350 cab n chassis (didn't come with a bed.you added it.narrower leaf springs and frame.)
is the donor dually a cab n chassis or a pickup.the axles are not the same.only the dually pickup axle will bolt into your f250 and make it a dually.
you can tell via the vin or measure the frame.tip; the cab and chassis didn't come with pickup beds.if you see it's clearly sporting a dually pickup bed (and it lines up without looking funny) then it's "probably" a pickup.the vin tells all.
Your door tag if a C&C should say "INCOMPLETE VEHICLE MANUFACTURED BY" at the very top, atleast my 91 does. But about the easiest way to tell if that truck is a C&C is go measure the width of the leaf springs on the F350, if you get a 2 1/4" (2.25") measurement its a cab & chassis truck and you can't use the rear axle to put in your F250. If the springs are wider than that assuming your truck isn't a F250LD as mentioned above you're GTG.
Received 3,090 Likes
on
on
he starts over in post #5 which clears everything up and makes the thread title correct.unlike how he worded things at first in post #1.
it's messy lol but i think he goes as follows:
95 f250HD with new engine and trans will be the keeper.a freshly put together 460/zf5 towing combo.
the 96 f350 dually is the donor truck,which sports the donor DRW axle for the f250hd axle & rim swap......at least he's hoping it is.
on
Is the 96 F350 a DUALLY PICKUP or DUALLY CAB-N-CHASSIS?
The dually pickup axle is 6" wider than a SINGLE REAR WHEEL axle
The DUALLY cab-n-chasi axle is about 3" wider than the SRW axle AND the spring perches are in the wrong spot to bolt into a PICKUP
So AGAIN, what is the 96 F350
on
"A friend got me a 1996 F-350 w/7.5L but I am going to just use the ZF trans, Drive line and the rear end is the dually I was talking about."
see how things changed?
of course he can come back to clear things up and hopefully and just start from scratch again.no sense trying to weed through a mess.
but,there actually would be a very very important reason why he would swap the axles if he's starting with a drw and wants to run the 96 drw as a srw truck.
lets say its a pickup;
reason one:
drw pickup bed $1000 -$1500 these sometimes sell for (i know,i know.crazy right? i didn't pay much more for a nice dump bed! lol)
reason two;
the drw pickup axle $500-1000 (i recently payed in between this myself for one,then had to buy all new brakes and drums)
drw rims;
easy $50 each x 6 = $300
so if a guy wanted to convert his drw pickup to a srw pickup.it could prove profitable to swap in the much cheaper srw pickup bed (or build a flat bed) and stick a srw sterling under it found about anywhere for $100-200.
take off the front hubs and sell those with the whole conversion kit too,and really make a nice hunk of change,while ending up with a basic srw truck.
in this case here,since he has an f250 which you think might be the donor (could be.i won't argue.he'll clarify if he comes back) he'll have everything needed minus some new u-bolts to swap over and the sale of drw parts = pure profit.
these dually convert threads don't have to get so complicated,but they almost always do.
Ben L
19
02-07-2019 07:57 AM
Josh Keller
04-07-2014 07:20 PM
Ford4Life7.3
13
06-10-2013 10:20 PM
