Rugged Wheel Liner
Rugged Wheel Liner
I came across these today I thought it was a pretty cool idea to save on my truck from the salt and mud its to bad Ford doesn't just put them on from the factory without an added cost. I see they are offered now they were not when I ordered my truck 2 yrs ago.
Rugged Liner Rear Wheel Well Liners 2009 2012 Ford F250 F350 Super Duty | eBay
Are these the same liners that SuperDutyScaler bought and the fit was horrible? In the Super Duty forum.
Matt, I'm with you...I'd be concerned with what gets trapped where they attach to the truck....especially the salt. Gotta love living in the snow belt!
UPDATE: I searched the SD forum and Rugged is the brand that SuperDutyScaler used. Based on that thread, seems like the fit was bad and he had to do a lot of work to get them to fit.
I don't think it can be any worse then what is on there now which is nothing. I have seen numerous SD around here rust out with Fords under the bed rails and fender supports. I ordered a set and cant wait to get them. I will let you all know how they fit!
Had them on my Dodge and they were the 1st thing I bought for the SD when I got it. We live in the country and they keep the rocks from pounding the box to death. Only word of warning is if you live where it get into the -30's like I do, put 4 or 5 coats of rubberized undercaoting on them first as they will shatter in the real cold when they get hit with rocks. The rubberized undercoating acts as a cushion. The only issue I had was modifying the mounting brackets for the mud flaps so everything fit. All told took me abt 2 hrs per side.
Update: Just go done installing these and I ran into two minor problems. First was on the drivers side when I went to install the push pin that goes into the frame rail there was already one from the factory that came the other way, looks like it holds some bracket on the inner frame rail holding up some wires so I just drilled a new hole in the plastic wheel liner that matched another frame rail hole no biggy. Next on the passengers side the two holes in the frame rail are to big for the push pins that are supplied so I had to run down to Auto Zone and get some bigger ones. The fit was bery nice I thought they can be a bugger to snap in around the outer fender well but all and all it took me about 30 minutes to install after I got done hosing the underneath really good. The other thing that if someone has factory mud flaps might want to put the clip that holds it in place on the plastic wheel liner that way when you put your bolt back in for you mud flap you tighten everything up together. Good Luck all!
