Operation psd rad on a gasser core support!
That makes sense I could see about doing that according to summit the rad for a 351w and a 460 are the same this doesn't seem right can any one else confirm this?
According to rock auto they have the same p/n so i could use the rad from the 351w and just get new hoses.
So on to a new round of questions:
Could i use a flexible hose from summit so theres no need for welding?
What would it hurt anything if i went with a reservoir instead of a surge tank?
Dude, find you a dsl rad support donor, all you need to be good on it is the center section. Mine was bad where it bolts to the frame. I bought a gas rad support and cut the center sections from both, weld the dsl section to the new, and you have a new support. This is an easy fix for even a novice DIYer. I wish I had taken pics when I did mine. I am not convinced that the dsl without ac support is not the same. I would have to see one to believe it.
If you end up deciding against the e-fans, give me a shout. I'm local and have three PSD fans (with the clutches) sitting in the loft of the shop. I'd be happy to let you have one for a reasonable price. I too, have been running no fan for a couple months and have had zero trouble with it, but in this weather, I'm obviously not using the A/C.
#28
I'm not sure on the exact difference of the 2 rad supports, but if thickness is an issue, maybe consider a E-series radiator. They are single core and 1/2 the thickness of the trucks. I've seen some vans/box trucks pulling & working and they don't seem to have overheating issues.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
