Borg Warner T85N question...
I have a T85N trans with the yoke bolted to the rear. It has a tag that reads C5T3C. Can any one shed some more light on what I gots? I'm in the process of adapting it to my '55 F100. A little machining to open the bell to fit the input shaft cover, finding or making a longer pilot bearing to make up for the shorter input shaft, etc.
Borg Warner T-85N 3 speed O/D optional for: 1965/67 F100 240/300 I-6 & 352 / 1968/71 F100 240/300 I-6 & 360/390 / 1969/71 F100 302.
1965/71 F100 Warranty Plate TRANS code: B
Some of the O/D unit's internal part number prefixes begin with 16H = 1941 Lincoln Zephyr/Continental.
Thanks for the info! Are parts for these as hard to find as I imagine? Are any of the parts from my t86/r10 interchangable?
Shoulda asked this question in the 1964/72 forum.
I'd have to look up the T-86 O/D parts and compare with T-85. I'm not that far away from Riverside, if you'd like to do a comparo.
Thanks for the offer Bill. I grew up in Whittier and La Mirada. Might drop you a line sometime when I'm visiting the folks. Tomorrow I'm planing to pull the overdrive off of the t85 and have a look see inside before I mount it up. Think I might pull the t86/r10 apart too, just to see if anything broke in the OD. My t86 is 12v also so I'll be holding on to the solenoid and gov.
There should be operation/repair manuals for FREE download here:
Deve's Antique Chevy Truck Restorations | Borg Warner 3-Speed Overdrive Index
tommyduncan
19
05-29-2022 07:45 PM
hooterville
01-27-2019 11:20 AM
fakirone
06-18-2012 02:53 PM
