Is the Expy a Poorly Built Vehicle?
gcspray: Did you end up going with the HD trans? I'm interested in what you think of it.
Our Expy is the same as yours other than it's a 2000 EB. We bought it used to replace a POS Chevy Tahoe that was purchased new and babied. The two do the same work: 80% towing a 2 and then a 3 horse trailer. You can tell your shop friend the Tahoe couldn't even handle the light 2 horse trailer
We've re-done the air suspension, an alternator, fuel pump and a drivers window motor/winder and otherwise regular maint. While it gets good mechanical maintenance it sits outside all year and still has shiny paint. Since we tow with it so much, I do drain and fills on the trans every 10k miles or so: 6 qts out and 6 in -- switched to Mercon V a couple of changes ago, also do 5k mi. OCIs...
I'll be interested to know what you decide to do transmission-wise as if ours ever goes I'd consider a built up one too.
grandisp
2015 + Expedition & Navigator
01-27-2018 08:46 AM
jaycaruso
1997-2006 Expedition & Navigator
02-12-2009 01:04 PM
