2001 Expedition - dumping raw fuel and missing - Ford Truck Enthusiasts Forums
Old 01-16-2013, 11:29 PM
domslivin domslivin is offline
domslivin is starting off with a positive reputation.
I have a 2001 Ford Expedition with 119,000 miles on it. I noticed a small what feels like a misfire at idle, fuel smell when it's cold, and big clouds of blueish colored smoke at cold starts. So I took it to Mike Naughton Ford and they said it was a fowled plug. $512 later, the plugs and boots were replaced and the problem still exists. I took back to them and they said they did notice fuel dumping out the exhaust at cold start, but the computer and diagnostics showed everything was within specs and sent me away. I replaced all 8 injectors, and cleaned the MAF sensor, checked all the vacum lines and still no change. So I took it to a small local shop who was willing to spend more time diagnosing things. The god a P0172 System to Rich Bank One The long term fuel trim on B1 is 10.15% on B2 - 4.68% Short Term fuel trim switching + ___ - 1.5%. They tested Oxygen sensors, voltages were good and switching fine, two compression tests and all 8 were ok and they determined it may be a leaking injector. I replaced all the fuel injectors before I took it into the shop so I was pretty sure that wasn't the problem but let them do their testing anyways. No leaks were found, the fuel pressure KOEO is 40psi., pressurized rails multiple times, no drips or leaks. System held 20psi. over night. In the end they said they agreed that something was definately wrong but were unable to determine what and sent me home $282 later with no fix in site. The only thing they could tell me is that it would need to fail before they could figure out what was causing the problem. I have a warranty on the vehicle, but if nobody can figure out whats wrong or admit there is a problem I can't keep throwing money down the drain for diagnostics. If you have any advice I would greatly appreciate it.
Old 01-17-2013, 09:14 AM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
Get a noid light. I have seen injector drivers stick on and hold the injector wide open. The light is available at you local auto parts store such as autozone. It plugs into the injector plug and while running you should have a a flicker of light which means the injector is getting the proper pulse signal. If one is brighter than the rest or solidly lit, then the ECM is bad. I have had 2 different vehicles do this, but they stuck wide open. It was ugly!!
Oh, by the way, welcome to the forum. Good luck on your repair.
I'm moved this the the fuel/efi system so you might get better replies.
Old 06-04-2013, 06:22 PM
Update
So I replaced the PCM, IAC Valve, and had a leak down test done. The leak down test showed all the cylinders between 160 and 165. I also had the temperature sensor checked with an ohms meter and it showed it was working properly as well. There is still a misfire and it's still dumping fuel! I see nobody has responded to my ad here with any suggestions so I guess I'm going to start posting on other forums to see if I can get any more suggestions.
Old 06-05-2013, 06:00 PM
LxMan1's Avatar
Blue smoke is usually from the valve seals allowing oil to get into the cylinders when sitting.
How bad is the misfire? Is it all of the time or just when cold?
Old 06-05-2013, 11:04 PM
The misfire is constant, but not extreme. You can notice it sitting at idle, but it's not a constant. That's why I had the leakdown test done because I assumed it was valve seals as well, but the test came back ok and they checked all the plugs when they pulled them and they apparently looked ok as well. I'm guessing it may be an electrical short at this point since I've tested everything mechanically at this point.
Old 06-09-2013, 12:03 AM
Well I traded my expedition in today for a new vehicle so I guess this thread can be deleted now, I just couldn't figure out how. Thanks~!
Old 06-16-2013, 12:06 AM
gman97005's Avatar
gman97005 gman97005 is offline
gman97005 has a good reputation on FTE.gman97005 has a good reputation on FTE.
Quote:
lol, that's one way to fix the problem !!
Old 06-18-2013, 05:42 PM
LxMan1's Avatar
You can not delete a thread. I hope the replacement vehicle stays trouble free.
Old 06-23-2013, 10:01 PM
gman97005's Avatar
Now that i look back on it i am 99% sure it was faulty MAF sensor..
Injector Diag help 2007 f350 rotun 6.0L Power Stroke Diesel 15 11-22-2016 08:40 PM
2004 F-150 FX4 5.4L Triton Rough Idle GCosta 2004 - 2008 F150 2 03-04-2016 09:57 AM
Shaking engine 19887.3IDI Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 27 12-07-2015 12:22 AM
6.0L No Start Mystery dpassarella 6.0L Power Stroke Diesel 17 03-30-2014 07:55 PM
Random codes, sensors changed, ECM rebuilt, still runs badly. Stevil 3.8 & 4.2L V6 3 05-02-2012 06:55 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
