Rear Disc Brakes on a 1991
What would be my best options for putting rear disc brakes on my 1991 F-250 Custom 2WD using Ford parts? I have seen that the F Super Dutys have rear disc brakes but i'm not sure if the brake hardware will interchange with my drum brake hardware on my 10.25" Sterling axle housing. Would it be easier and cheaper to swap out the whole rear axle assembly and if so what model and year of truck would be the best donor? F-350 or E-350 maybe? I want parking brakes that also work like normal ( at the Caliper ) without having to go to a Driveline brake. Thanks ahead of time for any information.
Received 3,103 Likes
on
I plan to use the truck for towing a 26' fifth wheel travel trailer around the western US which is pretty mountainous. The Truck is equipped with the IDI 7.3 Diesel so it has plenty of torque for towing. I just want equally good stopping. I also like the ease of inspection and service on disc brakes a lot better then drums.
That's kind of what I thought to Thanks! It looks like I've got some crawling and Measuring to do.
You are right all the ones I have seen are Dana's as well so to go that route would probably require swapping in the whole axle assembly and relocating the Shock and spring mounts. It may still be worth doing though.
Some helpful links for converting your existing Sterling 10.25 ti disc:
1989 Ford F-250 Disc Brake Installation - Four Wheeler Magazine
Ford Rear Disc Brake Kits for 9", Dana 60, Dana 70 and Sterling
Ford Sterling Disc Brake Bracket 84-94 - RuffStuff Specialties
