03 F150 4.2L V6 PCV Valve WITH PICTURES - Ford Truck Enthusiasts Forums
Old 01-16-2013, 11:17 PM
one4house one4house is offline
one4house is starting off with a positive reputation.
I only registered for the forum so that I could make a thread with detailed pictures of where the PCV valve is on an 03 F150 V6. I recently couldn't find mine and noticed that no one ever puts up pictures. What a pain for those that are searching.
It is on the passeger side of the INTAKE MANIFOLD. IT IS NOT ON THE VALVE COVER LIKE I HAVE SEEN STATED IN 99% of the threads over the matter.Here it is with 1 of the three hoses disconnected.
And here it is with 2 hoses disconnected. The 2 small hoses are heater hoses. The big hose is the actual pressure release tube that goes down to the valve cover.
Here are all three hoses taken off. You will need a T-20 torq bit to take it out of the intake.
Here is it completely removed.
And the notorious little baby removed.
I noticed, after 125,000 miles with no problems, a mysterious oil depletion problem. As you can tell by this picture:
It looks like my PCV valve was stuck open causing oil to flow into the intake. THe mystery of the F150 PCV valve SOLVED!
Old 01-16-2013, 11:59 PM
Lime1GT Lime1GT is offline
Lime1GT is starting off with a positive reputation.
Good pics. thanks
Old 03-31-2014, 08:47 PM
Tifford Tifford is offline
Tifford is starting off with a positive reputation.
This might be a little old but I have to ask,
The big hose that goes back to the valve cover. Do you think that it would be a good idea to put some clamps on both ends of the elbow? Mine slides off with little effort.
Old 01-16-2016, 12:23 AM
avs_23229 avs_23229 is offline
avs_23229 is starting off with a positive reputation.
Great pics one4house. Please help me with part number.
Old 12-03-2016, 11:40 PM
ravenousj's Avatar
ravenousj ravenousj is offline
ravenousj is starting off with a positive reputation.
the part with you've taken off with three hose connectors, what's the correct name? because if you follow that center big hose it leads to the pcv that's on the valve cover.
Old 12-04-2016, 10:54 AM
Sam I Am's Avatar
Sam I Am Sam I Am is offline
Sam I Am is gaining momentum as a positive member of FTE.
Quote:
That is the PCV valve.
Old 12-04-2016, 02:36 PM
ravenousj's Avatar
Old 12-04-2016, 02:37 PM
ravenousj's Avatar
so there is two pcv valves?
Old 12-04-2016, 03:04 PM
Sam I Am's Avatar
Apparently 2001 and 2003 4.2 take a different PCV valve.
Old 12-04-2016, 03:10 PM
ravenousj's Avatar
i do have that pcv valve that is first posted here and looks like it is leaking a little oil. i already changed out the pcv valve that i posted. im just trying to find a air leak. getting the p0171 p0174 banks too lean. also installed new fuel filter.
How to remove heated pcv from coolant bracket Bobalouie 1997 - 2003 F150 3 08-22-2015 08:07 PM
oil film in PCV vacuum line johaner78 1973 - 1979 F-100 & Larger F-Series Trucks 14 12-22-2011 02:13 PM
Ford 6.8L V10 Vacuum Line Diagram raidscsi Modular V10 (6.8l) 3 06-17-2011 10:14 PM
help!!! exact location of PCV on 02 4.2 - F150 khadma 3.8 & 4.2L V6 2 10-16-2008 09:53 AM
01 Sport Trac Vacuum problems edmondsonk Explorer, Sport Trac, Mountaineer & Aviator 1 05-10-2008 05:47 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
