Ford Panther platform suspension swap into f100 frame
in the mid 50's through late 70's f100 truck sections
a few people have been swapping the crown vic front and independent rear suspensions into their trucks. some are using the mustang or thunder bird rear ends.
i'm starting with this post. hopefully a following of tech. info on doing the swaps… so if you have done the hard work of pioneering the suspension swap or are doing the swap.
please post your photos and notes on doing the procedure.
thank you.
the basic change from solid axle or twin i-beam
completed f100 frame with a crown vic front and a mustang rear irs
a custom built aluminum frame...
here is photo of a rear 4 link
thank you.
Xchamp
124
11-10-2021 07:50 AM
