Anybody know the stock tie rod length on 52 F3 - Ford Truck Enthusiasts Forums
Old 01-16-2013, 07:58 AM
cruisetopdown's Avatar
cruisetopdown cruisetopdown is offline
cruisetopdown has a good reputation on FTE.cruisetopdown has a good reputation on FTE.
I need to replace my tie rod and end on my 52 F-3 due to the fact that it is bent like a spaghetti string. I measured it at 49" from tie rod to tie rod centers, the problem is it's bent pretty good. I straightened it best I could.....
Speedway Motors sells a 7/8 OD 11/16 tie rod ends kit for 54 bucks, but they list 48" (-1/2 - +3/4), next length is 52"
Will the 48" be long enough?
Old 01-16-2013, 09:08 AM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
Parts CD shows F-1 thru F-3 all use a 45-13/16" tube.
Old 01-16-2013, 10:32 AM
Thanks Ross, this truck is/was a Kansas farm truck and everything is worn out! I have new springs front and rear, shackle bushings/pins, etc. that should arrive today, new king pins will be installed next week and hopefully I'll have her back to a roller soon!
w
78 F250 new tie rod help bryanmartin 1973 - 1979 F-100 & Larger F-Series Trucks 6 07-27-2015 08:06 PM
Inner tie rod too long CWPLUNGIS 1987 - 1996 F150 & Larger F-Series Trucks 4 05-09-2015 03:35 PM
Replacement parts dougcepress 1999 to 2016 Super Duty 2 04-21-2015 06:26 PM
1955 F100 Stock Front End DGMFORD 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 02-01-2015 11:15 AM
Need some info about my 06 F150 5.4 BabyG555 2004 - 2008 F150 4 01-05-2014 12:06 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
