Working on the 68...
The bed had some issues (rust) and it was getting worse... So I Banged out most of the bad dents and welded the wheel well where they were pulling away from the floor... Then I sanded it down... Used naval jelly... Wire brushed it... Got rid all of the rust and sealed it...
Then I rolled in a bed liner... I know its not the best but it will work for now...
Now for the fun part... I love the grill I have but it is a little beat up...
So I have pulled the Headlight surrounds off and started straighting them...
The surrounds have several dents... And a small Crease...
So here is the first round of working them out... This is going to take a while...
One of the last big things was the dash pad.
It was really cracked up and I didnt want to spend $300+ replacing it...
So I pulled it off...
Then I dug out the Defroster Vents...
I stared cleaning them off and I thought the brushed look might be ok...
I then welded up the holes in the dash and stared filling them...
Then sprayed the dash flat black like the rest of the truck...
This looks glossy, but I took the photo when it was still wet... I flatten out nicely... I am letting it cure for a few days before I wet sand it and spray it again. I am going to pull all of the interior and spray it all at once this time...
I guess now with the rain coming down, I started working on the interior...
The headlilner is shot...
I have put anything in it place but I will be sound proofing and probably putting up a stained hardwood liner. I wanted it to match the color of the steering wheel.
I have also pulled off the metal trim on the dash. I have brushed them and they match the defroster vents and the center of the steering wheel...
I still have to Finish the body work on the driver side. Hopefully the weather will hold up... Im doing everything in an Apartment parking lot... If it is still raining on friday I will be pulling the rest of the interior out and finishing the Flat black on the inside.
This spring I will be working on a Crown Vic swap... I have already found the front end, I just have to get time to go get it. I will have to rent a garage when it comes to the front end... Wont be able to get around it... I'm still trying to deside what to do with the rear end...
I posted a long time ago about a squeeking/popping from the bed... I thought it was a bed mount or a shock bushing. Drove me insane...
Well I saw something between the bed and cab. I couldn't tell what it was. I grabbed a 2 foot socket extension and tried to knock it out... It didnt move... I had to use a 3lb sledge with the extension and beat the thing out... It was a piece of wood... Hard as a rock...
Now... No more noise... Thank god...
