A Long Time Coming...My Supercab
#76
Ha yes. It had a home in my other 79, but with so many projects on the go it has been sitting. I never had a chance to install it, so it will get some use now.
One thing about building a truck from so many different models and years, you never seem to stop swapping parts and looking for a better "fit" or option!
#80
Everything is posted at the beginning of the thread. Love these tires. Car hauler is hooked up and hauling a load the the swap meet early am.
#82
#83
There are 2 styles with 2 ratings, the close ratio is used behind a diesel and the wide ratio is for gas motors. After that you have the zf42 and the zf47, I was told that these are torque ratings and are about 45% of the total amount of torque that they can handle. Zf42- 420lbs, Zf47- 470lbs. The next thing is that the small block zf has an internal slave cylinder and release bearing in one unit, mine cost $190 but its the metal version not the plastic one. The big block version has an external slave cylinder. If you see a 88or newer f450 thats getting parted out you can get a hydroboost system with a trany break.
#84
#85
Been having some trouble with my truck. When cruising steady at 2000-3000 Rpm I am getting a steady popping sound coming from the exhaust.
Plugs are good, wires good, fuel pressure good.
I unhooked the vacuum advance and it went away completely. Hooked back up, did it again.
Any idea what would cause this??
429/ Quick fuel 780 vacuum advance carb
MSD vacuum advance dist.
Aaron-71
237
01-24-2018 08:32 AM
Coltin1992
23
09-04-2016 12:20 PM
