Clutch pedal parts numbers help please
Old 08-19-2012, 04:49 AM
jsnbuck's Avatar
jsnbuck
jsnbuck is offline
Could somebody provide the parts numbers for the following parts for my 76 F250 4x4 please? A schematic too if possible.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Clutch lever control
Clutch pedal assist spring
plastic bushings that the clutch pedal assist spring hook on (what are they actually called?)
Thank you.
Old 08-19-2012, 08:38 AM
mikeo0o0o0's Avatar
mikeo0o0o0
mikeo0o0o0 is offline
Here's the exploded diagram of the clutch linkage, let me know which part numbers you need and I'll look them up.
Click on the .pdf link to view.
Old 08-19-2012, 02:09 PM
jsnbuck's Avatar
jsnbuck
jsnbuck is offline
Thank you Mike. I need the part numbers for:
7A554
7A600
7A630
7519
Old 08-19-2012, 02:10 PM
jsnbuck's Avatar
jsnbuck
jsnbuck is offline
Oh, I need 2A309 as well.
Old 08-19-2012, 03:59 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Okay, here it goes:
C1TT-2A309-A Bushing
Green Sales, Cincinnati, OH has 22 (800) 543-4959
Dennis Carpenter Obsolete, Concord, NC has 5 (704)786-8139
JST Automotive, Lebanon, TN has 1 (615) 443-3086
Freese Motor, Inc., Monticello, IA has 1 (319) 465-3541
Don Sanderson Ford, Glendale, AZ has 3 (623)842-8643
D3TZ-7519-A Pedal, clutch
Collectors Auto Supply, Oroville, WA "MAY" have one.... or more. Their inventory control sucks. The quantity on hand is always 22 regardless of how many they may or may not have. Quite often they show "22" but it is actually "0". (800) 414-4462
C8TZ-7A554-A Lever, 3 3/4" long X 1 1/8" wide with 1 hole on each end
Green Sales has 2
Don Sanderson Ford has 1
McSpadden Ford, Globe, AZ has 1 (928) 425-4491
D3TZ-7A600-A Spring, 6 3/8" free length 21 3/4 coils
Green Sales has 2
Dennis Carpenter has 4
JST Automotive has 3
Tison Motor Co., Estill, SC has 1 (803) 625-2551
Parts International, Farmers Branch, TX has 7 (972) 241-8730
D3AZ-7A630-A Insulator, U-shaped
Green Sales has 1
Wesley Obsolete Parts, Liberty, KY has 1 (606) 787-5293
Old 01-16-2013, 09:07 AM
grasfarmr73's Avatar
grasfarmr73
grasfarmr73 is offline
Is the z bar the same between the 300 and the v8s? I swapped to the 300 and my z bar is not level to the floor.
Old 01-16-2013, 10:40 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
V8 engine side pivot different than I-6.
C8TZ-7528-B .. Clutch Equalizer (Z) Bar ~ Shaft 5 1/2" long / Obsolete ~ ONE available NOS
I-6/V8; 3/4 M/T; 2WD/4WD makes no difference except as noted.
Applications: 1968/72 F100/350 (except 1969/72 F100 302) / 1973/76 F100/350 all.
240/300: The bar rides on nylon bushings (C1AA-7543-A ~ available from Ford) on a frame mounted pivot and engine side pivot that threads on.
V8 pivots: One on frame, one made a part of a bracket that bolts on. Do you have the I-6 pivot? Probably not since the bar is catty wampus.
C5TZ-7A535-A .. Engine Side Clutch Equalizer Bar Pivot / Obsolete ~ ONE available NOS
Applications: 1965/76 F100/350 240/300 I-6 / 1969/76 Econoline 240/300 I-6.
Last edited by NumberDummy; 01-16-2013 at 11:07 AM. Reason: Edited in I-6 clutch pivot info.
Old 01-16-2013, 11:25 AM
montana_highboy's Avatar
montana_highboy
montana_highboy is offline
There's two available NOS if you need/want one, part #C8TZ-7528-B
Wesley's Obsolete Parts in KY has (1)
C&G Early Ford Parts in CA has (1)
Wesley's will usually 'work' with you on price a bit, not much though, about 5-10%
Old 01-16-2013, 11:37 AM
NumberDummy
i
Wesley Obsolete Parts in KY has (1)
(sigh) "Another cat oughtta the bag." I sent the OP a P/M, cuz when there's only one or two parts available, if the source(s) are posted for all to see, someone else might snag the part(s).
I didn't send the OP a P/M inre to the ONE available NOS clutch pivot yet (found it...guess where ), cuz I'm waiting for a response.
Old 01-16-2013, 11:47 AM
montana_highboy
i
Well ND, i thought the chances of both Z bars being snagged up were pretty slim, but stranger things have been known to happen.
Old 01-16-2013, 11:51 AM
Autofair Truck Parts's Avatar
Autofair Truck Parts is offline
Former Vendor
1980 clutch pedal part$
E1TZ 7519-A
Old 01-16-2013, 11:52 AM
NumberDummy
Look at the applications for the puppy, fits faaar more than 1973/76. Consider that FTE has over 650,000 members and consider you don't have to be a member to read posts.
How many resto shops, ebay high binders and snakes like Bob Allen Ford who buys low and sells SKY HIGH read these posts?
D4TZ-17696-A Type 9 Low Mount Swing-Lok Mirror. ebay seller had them for sale cheap: 30 bucks, 20 bucks LESS than last dealer net cost!
Member of this forum was looking for some, I gave him the ebay ref, he bought all THIRTY THREE of them!
Now there's none available NOS for you, me or the fence post, as no Ford Dealer or obsolete parts vendor had any before I gave him the ref.
I'll never do that again.
Old 01-16-2013, 12:12 PM
montana_highboy
I found five, part #C5TZ-7A535-A
Collectors Auto Suppy in WA has (22) *i'm not too sure about the accuracy of C.A.S. inventory numbers*
JST Automotive in TN has (1)
NOS Parts Ltd. in TX has (1)
B&B Auto Parts Llc. in NY has (2)
NOS Only in CA has (1)
Old 01-16-2013, 12:23 PM
NumberDummy
Originally Posted by Autofair Truck Parts
1980 clutch pedal part$ E1TZ 7519-A
E1TZ-7519-A (replaced EOTZ-7519-B) .. Clutch Pedal / Obsolete
1980/83 F100/350 & Bronco (except 1983 F250/350 6.9L/7.5L) / 1983 F150/250 & Bronco w/351W
The 1980/89 Ford Light Truck Parts Catalog is available on a CD from hipoparts.com
Old 01-16-2013, 12:28 PM
NumberDummy
I don't list Collectors unless NO ONE else has the parts. Have you ever dealt with them before? They're a middle-man operation, buy from one, sell to another.
You call, they say we gotta check the warehouse (it's in BC Canada), will call you back. But they usually don't call back so, the whole process has to be repeated again.
How may D4TZ-17696-A mirrors can you find? See post 12.
NOS LTD PARTS bought out Ed Bennett Ford Parts in Lebanon PA, but he didn't get the 'cream.' Ed kept all of it so he can hob *** at Carlisle with his pals.
You're getting pretty good at this, whiz on by, I'll sell you every parts catalog/microfiche slide, viewer I have, and retire. Then you can spend 10 hours a day looking this crap up.
And don't expect a cent for doing this 'good deed.'
Quick Reply: Clutch pedal parts numbers help please
