Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 01-15-2013, 10:49 AM
Spitfire44 Spitfire44 is offline
Garage is empty, add now
Spitfire44 is starting off with a positive reputation.
No Power to Coil
'59 223. Ran when turned off. Next time I went to drive it the engine would start, then die when I released the key from the start position.
I narrowed it down to not getting 12V to the coil. Pulled the key assy. I'm getting 12V to two terminals in the on position. Checked wiring leading to the coil. All looks fine, but no power. Without a wiring diagram I'm having trouble tracing. Any ideas on what the trouble may be?
  #2 (permalink)
Old 01-15-2013, 11:30 AM
hiball3985's Avatar
hiball3985 hiball3985 is offline
1960 Ford F-100
My Garage
hiball3985 is starting off with a positive reputation.
Try jumping the ballast resistor.
__________________
JIM
1960 F100 Panel 223 3 spd overdrive
1966 F250 390 4 spd
1957 Ranchero 292 3 spd
  #3 (permalink)
Old 01-15-2013, 02:20 PM
f5fordgirl f5fordgirl is offline
f5fordgirl is starting off with a positive reputation.
If it starts, and then dies when you let go of the key, the switch is bad. It starts cause its getting the full 12 volts from the selonid, when you turn loose of the key, the switch isn't supplying juice to keep it running.
  #4 (permalink)
Old 01-15-2013, 02:34 PM
hiball3985's Avatar
1960 Ford F-100
My Garage
Quote:
Not necessarily true. When the key returns to the on position the power goes through the resister before the coil. So it could be either or anything between.
__________________
JIM
1966 F250 390 4 spd
  #5 (permalink)
Old 01-15-2013, 03:01 PM
theodore/teddy's Avatar
theodore/teddy theodore/teddy is offline
theodore/teddy is starting off with a positive reputation.
My money is on the resistor.
This happened to me on Teddy in 1973 I was going to my first night on a new job and he would start then die when I let off the key I didn't have time to mess with it, so I ended up riding my horse to work that first night. Needles to say I was the only one that showed up on horse back and it was a topic of conversation that stayed with me while on that job.
__________________
Looking for an in bed spare tire mount for styleside fridge bed.
1959 F250 4x4
Wally
  #6 (permalink)
Old 01-15-2013, 03:08 PM
hiball3985's Avatar
1960 Ford F-100
My Garage
Hi Ho Silver
__________________
JIM
1966 F250 390 4 spd
  #7 (permalink)
Old 01-15-2013, 05:01 PM
vntgtrk's Avatar
vntgtrk vntgtrk is offline
vntgtrk is starting off with a positive reputation.
It's already been covered that it's either switch or resistor. The resistor is the easiest to jump, so try that first. Then, before you go ordering a new switch, get the DVOM out and check resistance thru the whole circuit. I had a '65 do this and it was a short to power at the base of the steering column Too long ago to remember the gory details.
  #8 (permalink)
Old 01-15-2013, 11:37 PM
chetspencer's Avatar
chetspencer chetspencer is offline
2005 Ford Excursion
chetspencer is starting off with a positive reputation.
That's a great story and some serious work ethic! I've been in a similar situation back when I was a kid. Don't want to hijack though
__________________
Chet
1959 F100 4X4 Custom Cab Styleside
2003 F250 4X4 Extra Cab Short Bed
2005 Excursion limited 4X4 6.0L
  #9 (permalink)
Old 02-18-2013, 09:25 PM
Wanted to follow up on this. It was the ballast resistor that failed. Plugged a new one in and it worked. Jim was correct. When starting, the switch sends 12V directly to the coil. After the engine starts and the key returns to the on position, power to the coil goes through the ballast resistor. The decrease in voltage is supposed to make the points last longer.
  #10 (permalink)
Old 02-18-2013, 09:28 PM
hiball3985's Avatar
1960 Ford F-100
My Garage
I'm glad you got it running . Also without the ballast resister the coil will over heat and burn out fairly quick.
__________________
JIM
1966 F250 390 4 spd
  #11 (permalink)
Old 02-19-2013, 07:18 AM
ibuzzard's Avatar
ibuzzard ibuzzard is online now
We'll Always Have Poway..
ibuzzard has a very good reputation on FTE.ibuzzard has a very good reputation on FTE.ibuzzard has a very good reputation on FTE.ibuzzard has a very good reputation on FTE.
Spitfire, glad you got it figured out. I also went thought the puzzlement of a bad ballast resistor, ready to rip out my entire ignition system. Then another member told me to save my money and replace the inexpensive resistor first, before replacing the relatively more expensive coil and ignition switch, etc.. That proved to be the problem.
I have since upgraded by getting rid of the points. First, I used a Pertronix Igniter, one model of which has you bypass the ballast resistor. But finally, I replaced the stock distributor entirely with an MSD electronic one, and am happy with no maintaining of the points, better acceleration, no ballast resistor, and much easier starting.
__________________
"Why, yes, I have plenty of spare change, you worthless piece of crap."
'59 F250 w/an Engine, a Transmission, Some Tires/Wheels, PLUS-a Genuine Radio
" Show me your Tee-Hee, I'll show you mine."
  #12 (permalink)
Old 02-19-2013, 07:27 AM
vntgtrk's Avatar
With all the options out there it really makes no sense to keep running points. I elected to go with the Duraspark conversion with a GM 4 pin module partly cuz it looks cool. But a maintenance free system is good enough excuse to go electronic.
  #13 (permalink)
Old 02-19-2013, 01:32 PM
hiball3985's Avatar
1960 Ford F-100
My Garage
Quote:
I can't totally agree, all my Fords that I have had since 1966 have run points and I've never had a failure. I've known at least a dozen people and there are plenty more that have had the electronics fail leaving them on the side of the road....
__________________
JIM
1966 F250 390 4 spd
  #14 (permalink)
Old 02-19-2013, 05:27 PM
vntgtrk's Avatar
Quote:
Any ignition system can fail, don't care what's sending sparks to the plugs. And last I checked, points aren't like the good old days when 3 bucks got a tune up kit which included points, condenser and rotor.
If you wish to use points in your daily driver and don't mind changing points about once a year, whatever works best for you.
  #15 (permalink)
Old 02-19-2013, 06:31 PM
spurredon's Avatar
spurredon spurredon is online now
spurredon has a good reputation on FTE.spurredon has a good reputation on FTE.
I guess I don't make any sense either!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
