Center my steering wheel/adjust tie rods - Ford Truck Enthusiasts Forums
Old 11-17-2014, 07:51 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Wheels & Tires How-Tos
Print Wikipost
Old 01-15-2013, 09:36 AM
traderssd traderssd is offline
traderssd is starting off with a positive reputation.
Portland, Oregon
Hi Guys,
I have a stock '91 F150 2WD that's a real cream puff. It's in perfect shape and drives fantastic. I just recently put new tires on it and with that also had an alignment done. Like I said, it truly drives great except the steering wheel is slightly off-center. Most people probably wouldn't bother with it but for me, it very annoying and drives me crazy. It's only off one or two degrees........not a lot. Does anyone know the proper proceedure for adjusting the tie rod ends/sleeves to center the steering wheel without changing the tow-in on the alignment? I know it's a matter of turning the tie-rod adjusting sleeves but which ones and in which direction?
Sure would appreciate some help on this because I really don't want to take it back to the alignment shop as it's a huge hassle.
Thank you in advance for your help.
Stuart D.
Portland, Oregon
Old 01-15-2013, 10:45 AM
88n94 88n94 is online now
88n94 is gaining momentum as a positive member of FTE.
i can try to tell you how to do it, but there would be no guarantee that the toe adjustment would still be right on when you're done.
Let's say your steering wheel is turned to the right when you are going straight down the road. Turn the steering wheel straight ahead. Your tires will be headed left. So you will need to turn the turnbuckle to shorten the tie rod on the drivers side to get that wheel going straight ahead. You will need to turn the turnbuckle on the passenger side to lengthen the tie rod. You get the idea.
You can mark the turnbuckles before you start and count the number of turns you move them, but as I mentioned earlier I still kind of doubt if the toe adjustment would be right on.
Old 01-15-2013, 10:53 AM
merhlin merhlin is offline
merhlin is starting off with a positive reputation.
Take it back to where you got the alignment done - they should take care of it. I wouldn't mess with it after just having the front aligned.
merhlin
Old 01-15-2013, 12:10 PM
Freightrain's Avatar
Freightrain Freightrain is offline
Shiftoholic
Freightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to behold
Leave the wheels straight, the steering wheel will be cocked. Leave key in ignition so it's unlocked and will turn.
Loosen RH tie rod and give it one full turn. Go to LF side and give it one full turn the opposite direction. This will keep toe in correct and will move the steering wheel back. Just need to know which way it is off, so you turn them nuts the right way. Leaving the steering wheel loose will allow it to move and show you that you are turning things the right direction.
What happened was the alignment shop only turned ONE side when they corrected the toe in and didn't reconfirm the wheel is centered(like a good shop would). Not a big deal, easily fixed without hurting anything.
Old 01-15-2013, 12:13 PM
DIYiT's Avatar
DIYiT DIYiT is offline
DIYiT has a good reputation on FTE.DIYiT has a good reputation on FTE.
Quote:
merhlin
This. When I've had my alignments done, I've always taken it to places with a 30 day guarantee so that things like this are a no question fix by the shop.
Old 01-15-2013, 04:17 PM
Splash_O_Yellow's Avatar
Splash_O_Yellow Splash_O_Yellow is offline
Splash_O_Yellow is starting off with a positive reputation.
or you could pull the steering wheel, move it like one spline or two and reinstall the nut to hol it on. that old of a truck and you wont have to deal with an airbag or the chance of it going off. just my $.02
Old 01-15-2013, 04:39 PM
bashby's Avatar
bashby bashby is offline
bashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to all
If you don't want to take it back, do like suggested, if the wheel is off to the right, lengthen the left and shorten the right, but 1/4 turn will probably be enough. The right outer tie rod has right hand threads and the left outer has LH threads.
Old 01-16-2013, 09:09 AM
Hi guys and thank you for the advise.
Not to be dumb but if my steering wheel is off to the left, know I need to lengthen the tie rod on the drivers side and shorten the tie rod on the passengers side correct? So which direction do I turn the tie rod adjusters to do this?
Old 01-16-2013, 09:23 AM
bashby's Avatar
Yes, that is correct. Like I said, the left outer tie rod has left hand threads, so to lengthen it you would turn the adjusting sleeve clockwise on the outer.
The right outer has right hand threads, so to shorten it you need to turn the sleeve clockwise on the outer tie rod. Move them both the same amount, about 1/4 turn should do it.
Old 01-16-2013, 09:57 AM
ok.......got it! Thank you so much!
Stuart D.
Portland, Oregon
Old 01-16-2013, 02:04 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is online now
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
The ONLY tie rod you touch to center the wheel is the Upper one. Where it connects to the pitman arm(steering box)
You loosen the collar bolts that connects the tie rod to the drag link then spin the collar.
If the wheel is off to the left, you spin the collar to SHORTEN the linkage.
If the wheel is off to the right, you spin the collar to LENGTHEN the linkage.
Then tighten the collar bolts and test drive. Keep adjusting in small increments till you get the wheel where you want it
DO NOT, I repeat DO NOT touch the outer tie rods out by the tires, this will just throw off your toe, that you just has set
Old 01-16-2013, 02:11 PM
bashby's Avatar
Brad, I think you are confusing with the F350's steering linkage, He has a F150.
Old 01-16-2013, 02:15 PM
Shiftoholic
These trucks only have two adjustments. The drag link goes all the way to RH side. The left side comes off the middle of drag link. You MUST adjust BOTH or you WILL screw up the toe in setting.
Here is a picture showing it. (it's 4wd, but same basic parts)
Newer trucks have a different arrangement, that allows it: (straight axle, but see the adjuster on the drag link)
Old 01-16-2013, 02:43 PM
I forgot how stupid for d was with the TTB and TIB
Old 01-16-2013, 02:46 PM
Shiftoholic
It's okay. We'll give you a pass today LOL!!
The TTB Thread dohc_chump 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 46 08-09-2015 03:57 AM
Trucks Gone Wild at Kirbys Kompound, Palmyra NY. 72f250CS New York Chapter 8 09-27-2013 12:21 PM
Emissions Testing Question on a 78 grovermyson 1978 - 1996 Big Bronco 9 04-27-2013 10:35 PM
sulastic rear shackles for smoother ride?? 4rdfvr 2004 - 2008 F150 19 10-17-2010 03:02 PM
bronco wanted 460stick 1978 - 1996 Big Bronco 4 10-03-2005 10:53 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
