Motorcraft oil for the 6.7 - Ford Truck Enthusiasts Forums
Old 01-15-2013, 10:35 AM
tolliewolly's Avatar
tolliewolly tolliewolly is offline
tolliewolly is gaining momentum as a positive member of FTE.tolliewolly is gaining momentum as a positive member of FTE.
Do you guys like the Motorcraft oil? I have always run rotella syn in all my past diesels but with this new truck, I want to just use all of Motorcraft Oil and keep the Ford Lords happy. I personally think its a good oil to use.
By the way I do lots of maintenance so I always change my oil at 5000 to 6000 miles anyways.
Are there any of you guys out there that run motorcraft religiously?
Thanks in advance!
Old 01-15-2013, 11:05 AM
Rod Bensken Rod Bensken is offline
Rod Bensken is starting off with a positive reputation.
This is my first Ford, so I'm letting the dealership handle the maintenance at this point. This is also my first diesel.
On my GMC I used Mobil One. It seemed to run about 15 degree's cooler that way.
Old 01-15-2013, 11:06 AM
Javi1 Javi1 is offline
Javi1 has a good reputation on FTE.Javi1 has a good reputation on FTE.
Ford Motorcraft 5W-40W Full Synthetic for me
strokin83's Avatar
strokin83 strokin83 is offline
strokin83 has a good reputation on FTE.strokin83 has a good reputation on FTE.
It's all personal preference really. I'm a big proponent of Synthetic due to oil analysis. My last one came back with a recommendation for 10,000 mile intervals while using the Rotella 5w40 syn. But I'm not saying the Motocraft is bad either I think if you stay within the factory interval your fine. There is a guy in the 6.0 forum that got 582,000 miles out of his original engine while using the Motorcraft brand. Sad thing is he thought the motor was bad so he pulled it to replace and found that he had a bad copper seal on the injector. And his internal engine components looked great considering the mileage. So that being said you have a good plan go with it haha.
Old 01-15-2013, 11:27 AM
Headspace Headspace is offline
Headspace is starting off with a positive reputation.
Me too
Quote:
5w-40 100% synthetic Ford oil because I ain't got no choice.
Just bought a 2013 f-350 6.7, 4x4, dually, loaded lariat. Paid a fortune for the 100,000 mi, 7 yr maintenance plan with 100% synthetic at 5,000 mi. My use is considered very "heavy", dusty and off road. Interstate and mountain roads with 6,000+lb. load (heavy cab over camper with lots of other heavy stuff like Road Armor bumper with winch, huge tool (gun) box in place of rear seats, etc.
It cost almost $2,000 more to go from fossil oil to synthetic on that plan!
Old 01-15-2013, 11:39 AM
kper05's Avatar
kper05 kper05 is offline
kper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant future
The factory fill was changed at 4,700 and I've run Motorcraft 15w-40 to my current 41,000 miles with 5,000-6,000 miles changes.
I may switch to T6 full synthetic next oil change but that depends on how much of the current oil I have remaining.
Old 01-15-2013, 11:49 AM
ruschejj's Avatar
ruschejj ruschejj is offline
ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.
I switched to T6 synthetic because its cheaper than the Motorcraft oil. I change my oil when the truck tells me too, which is usually around 7500 miles.
My penny pinching is due to the fact that I drive almost 6,000 miles per month, it all adds up quickly for me.
Old 01-15-2013, 01:08 PM
maistroyoda's Avatar
maistroyoda maistroyoda is offline
maistroyoda is starting off with a positive reputation.
Rotella is all I'd use
Old 01-15-2013, 01:31 PM
Tomahawk's Avatar
Tomahawk Tomahawk is online now
Tomahawk has a superb reputationTomahawk has a superb reputationTomahawk has a superb reputationTomahawk has a superb reputationTomahawk has a superb reputationTomahawk has a superb reputationTomahawk has a superb reputationTomahawk has a superb reputationTomahawk has a superb reputationTomahawk has a superb reputationTomahawk has a superb reputation
I run T6 in my truck, tractor and ATV's.
Old 01-15-2013, 02:03 PM
kper05's Avatar
Motorcraft was cheaper but not anymore.
I was getting it for $17 for 5 qts and now it's $26.
Same Auto Zone...
Old 01-15-2013, 02:33 PM
Hdslider's Avatar
Hdslider Hdslider is offline
Hdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputation
Ive run. Motorcraft synthetic blend inabout 7 different vehicles. Ive got a 94 f 150. With. 295, 000 miles never a anything done to it. Its treated my diesels well.
But im like Kyper 05. The price is starting me to thinking a different route may be ahead.
Old 01-15-2013, 02:38 PM
doczenith1's Avatar
doczenith1 doczenith1 is offline
doczenith1 is starting off with a positive reputation.
Walmart near me has T5 for $17 and T6 for $22. Mobil 1 is $27. I found Mobil 1 for $22 at Meijer so that's what I used when I changed my oil last week. The only Motorcraft they have at Walmart is 15W40.
Old 01-15-2013, 08:20 PM
Well thanks for everyone's thoughts. I may just run rotella syn then but I will def use motorcraft oil filters!
Old 01-15-2013, 08:46 PM
RM2012F350's Avatar
RM2012F350 RM2012F350 is offline
RM2012F350 is starting off with a positive reputation.
Rotella T6 and nothing else!!
Old 01-15-2013, 08:58 PM
kper05's Avatar
I couldn't even find Rotella T6 the other day at Walmart or AutoZone.
Doesn't seem too popular in my area.
Haven't had time to check Orileys but I'm betting they have it.
If not I'll spend more money driving two hours round trip to Tractor Supply because I know they have 1 gal for $24.
Oiling system upgrades/maintenance the_auto_tech 6.0L Power Stroke Diesel 10 01-20-2015 10:47 AM
maintenance. brandon.edwards 6.2L V8 8 06-29-2014 08:57 AM
Motorcraft full synthetic oil Mat523 1999 to 2016 Super Duty 9 04-08-2014 03:27 PM
Finalizing maintenance and modifcation list before starting next project the_auto_tech 6.0L Power Stroke Diesel 43 10-13-2013 10:33 PM
Reviewing a few things before moving on - the_auto_tech 6.0L Power Stroke Diesel 49 08-02-2013 10:38 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
