How to backflush the heater core????? - Ford Truck Enthusiasts Forums
Old 01-15-2013, 04:31 AM
Bruin008 Bruin008 is offline
Bruin008 is starting off with a positive reputation.
Title says it all. Just got finished watching a coolant flush video where he states to backflush the heater core after doing the vc9, but dosent say how to do such. Can somebody link me or explain it. Thanks
Old 01-15-2013, 04:34 AM
One other thing i forgot. Is it necessary to remove the thermostat while doing the coolant flush if i run the truck with the heat all the way on? By running the truck with the heat on, does that automatically flush the heater core?
Old 01-15-2013, 09:14 AM
I keep reading and reading on the coolant flush and people keep mentioning it, but nobody says how lol.
Old 01-15-2013, 09:48 AM
69cj's Avatar
69cj 69cj is online now
69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future
Quote:
1. Drain coolant
2. Add 2 cans of VC-9 and top off with distilled water.
3. Drive 20 to 30 miles, preferably at highway speeds.
4. Drain radiator at petcock first, then pull lower hose. Then remove block plug on driver side. Not necesary to do passenger side.
5. Remove t-stat. To do this, remove air cleaner. Then 2 nuts on t-stat housing. Pry press. sensor bracket off of studs. Tight fit but it will move. Remove 2 more nuts and pull t-stat and housing from studs.
6. Remove t-stat and put housing back on. Re-assemble everything and fill with distilled water.
7. Run at 1200 rpm's for 3 to 5 minutes and drain as described in step 4.
8. Repeat 4 to 5 times or until water coming at is as clear as water going in.
9. Install t-stat using new O ring. I used vaseline to hold the O ring in place.
10. After everything is re-assembled fill with a 50/50 mix of Ford premium gold or Zerex GO-5.
11. Start engine and check for leaks. This is a lot easier and quicker than it sounds. If you don't remove t-stat then you have to run truck between each flush till t-stat fully opens and then let cool down to work on it.
Highly recommend installing coolant filter kit while cooling system is empty.
Old 01-15-2013, 10:03 AM
ok, I have all that. What about back flushing the heater core? Or does it do it on its own. If that's the case, I',m good to go.
Old 01-15-2013, 10:42 AM
amdriven2liv's Avatar
amdriven2liv amdriven2liv is offline
I'm hitting easy street
amdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputation
Try this, page 18 or so. This is a good over all read, so, I might suggest having a cup of something and sit back and enjoy the read.
http://home.comcast.net/~lyon.family...ush%20v1-0.pdf
Old 01-15-2013, 02:12 PM
snorindad's Avatar
snorindad snorindad is offline
snorindad has a very good reputation on FTE.snorindad has a very good reputation on FTE.snorindad has a very good reputation on FTE.snorindad has a very good reputation on FTE.
Old 01-15-2013, 05:13 PM
Misky6.0's Avatar
Misky6.0 Misky6.0 is online now
Misky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputation
I've been thinking about how to flush the heater core(s) separately.
with the Excursion there is a long coolant flow all the way to the
rear heat unit.. and I think it makes it more work...
Just thinking... about the next time I have to do this
Perhaps using a spare set of hoses, we could bypass the heater core(s)
while flushing the engine/radiator.
Then use the original hoses to flush the heater core(s) separately, in reverse
direction if you pushed water through the other way?
Old 01-15-2013, 06:48 PM
CR3999 CR3999 is offline
CR3999 is starting off with a positive reputation.
where can I get the valve that fits into the block to drain the water out of the block. I have to change that little EGR cooling hose this weekend and might as well flush the system. I do have the dreaded green stuff in it now.
Old 01-15-2013, 08:19 PM
Quote:
are you talking about the blue or orange hose that connects from the egr cooler to the oil cooler? if so the stealership will have it. might have to check around with them since they proab wont all have it in stock.
Old 01-15-2013, 08:20 PM
this is what I have been looking for. Sad part is I have it saved in my favs, but I have like 200 other links also so I didnt find it lol. Think its time to clean my favs out lol. Thanks
Old 01-15-2013, 08:29 PM
F108N is the valve number.
Here is where one person found them:
Fumoto Engine Oil Drain Valve F108N : 16mm-1.5 / www.OilDrainValve.net
And here:
Search results :: Qwik Valve
Old 01-15-2013, 08:40 PM
BLADE35's Avatar
BLADE35 BLADE35 is online now
BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.
Take it apart at the Vac Valve and at the Degass Bottle and Stuff A Garden hose in the Coolant bottle side Turn on High water press let it flush
Hell Stuff the Garden Hose in Each Way in the heater Core Vac Valve too
Oh 1 Catch My Coolant filter Tyes Back into Heater Return that How I can Reverse Flush
Old 01-15-2013, 08:44 PM
BLADE35's Avatar
Here is How My Coolant filter Ties in
I Stuff the Garden Hose Into these Spots during Flush Does Great Job of Flushing the Heater Core
Old 01-15-2013, 09:03 PM
BLADE35's Avatar
Coolant flush for weeks! Question Waterlogged 6.0L Power Stroke Diesel 6 03-22-2016 01:46 AM
Coolant flush and backflush off the truck Pierdobek 6.0L Power Stroke Diesel 22 12-01-2014 12:27 AM
Flushing KDAVID1 6.0L Power Stroke Diesel 4 04-07-2014 07:22 PM
F250 Heater Core Help fordiesel69 1999 to 2016 Super Duty 4 11-10-2013 08:49 AM
How to do a quick heater core flush (with pictures) EXv10 Excursion - King of SUVs 23 07-15-2013 03:05 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
