Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Southwest Region > Oklahoma Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Oklahoma Chapter Join Chapter, Leader: Gary Lewis
  #1 (permalink)
Old 01-15-2013, 12:17 AM
GamerGirlAlice's Avatar
GamerGirlAlice GamerGirlAlice is offline
1971 Ford F-250
GamerGirlAlice is starting off with a positive reputation.
S.O.S. Tulsa Metro Broken Arrow OK Area
i was sending a s.o.s. to see if a nearby member can help me diagnose what happened to cause my 1971 f250 with a 360 to stop running?
Thanks in Advance, Alice
  #2 (permalink)
Old 01-15-2013, 06:59 AM
Gary Lewis's Avatar
Gary Lewis Gary Lewis is online now
FTE OK Chapter Ldr
Garage is empty, add now
Gary Lewis is a splendid one to beholdGary Lewis is a splendid one to beholdGary Lewis is a splendid one to beholdGary Lewis is a splendid one to beholdGary Lewis is a splendid one to beholdGary Lewis is a splendid one to behold
Can you describe what happened? What were the conditions and symptoms?
__________________
Dad's '81 F150 Ranger XLT 4x4 w/a 351M sporting an RV cam and Performer carb & intake/ZF5/3.50 gears w/Kevlar clutches in the rear LS, and sitting on 30 x 9.5 Starfire's wrapped around aluminum bullet holes
  #3 (permalink)
Old 01-15-2013, 10:35 AM
1971 Ford F-250
Quote:
well i bought it on the 9th and drove home fine & later i went n bought burgers and $25 of 87 octane fuel. on the 10th was cold and rainy but started fine, drove 1/2 a mile and it died at a traffic light. i see it pumping gas in carb, i replaced the plugs, wires, points, condenser, and coil. it already had a new cap and roater. but i just haven't been able to get it to start but it cranks hard and when it was running it had tones power and torc.
Click the image to open in full size.
Alice
  #4 (permalink)
Old 01-15-2013, 02:40 PM
Gary Lewis's Avatar
FTE OK Chapter Ldr
Have you checked for spark? The shot of the engine brought back memories for me of my '72 w/a 390 that died at a rest stop in AZ in '72. The coil just decided it was done.
So, plug a plug wire and hold it near the engine, probably with gloves, and have someone crank it. Or, put an old plug in the wire and put the plug against the block. You should have a white or blue spark. Obviously no spark is bad, and yellow or red is a problem but the engine should start anyway.
I think it must be ignition if it was running and died. So either you lost power to the ignition itself or something like coil, points, or wiring died. If you've replaced points since it died that might be a place to look if you don't have spark. Check to see that you have power to the coil, both when cranking (12v) and when in Run (~6v) And the points should take the other side of the coil to ground when they close.
__________________
  #5 (permalink)
Old 01-15-2013, 10:38 PM
1971 Ford F-250
i haven't checked spark since i got new coil. i have a mechanic coming tomorrow to help me with it. said would cost $25-$30 to diagnose my problem. so i am hoping my $125 can fix the problem.
  #6 (permalink)
Old 01-16-2013, 12:31 AM
1971 Ford F-250
i wanted to mention i found the mechanic via craigslist with a ad here: Need Cheep Mechanic for 1971 Ford F250 Work
  #7 (permalink)
Old 01-16-2013, 07:53 AM
MikeB 88's Avatar
MikeB 88 MikeB 88 is offline
2000 Ford Ranger
MikeB 88 is gaining momentum as a positive member of FTE.
Just out of curiosity, did you get the new points set right?
Maybe someone here in the group who lives in BA, can check out your truck instead of a stranger on craigslist.
__________________
Mike B
1969 ForDor Thunderbird
2006 Dodge Charger (wifes car)
2000 Ranger Regular cab
2.5L with A/C backed up by the 5 speed manual, 2WD.
159,000+ on the clock.
  #8 (permalink)
Old 01-16-2013, 08:25 AM
Gary Lewis's Avatar
FTE OK Chapter Ldr
Mike - That's one of my worries, that enough parts have been changed that there may be multiple problems, the one that caused the problem and those introduced later.
Alice - If it didn't start after installing the new coil it might still have been the coil as there now might be another problem. Hopefully your mechanic will be able to quickly diagnose the problem and you can then fix it.
__________________
  #9 (permalink)
Old 01-16-2013, 09:35 AM
MikeB 88's Avatar
2000 Ford Ranger
I remember many, many years ago a friend of mine Mustang quit running after a rain. Turned out that water had gotten into the distributor. We took the cap off, dried it out and it ran fine afterwards. Not sure how the water got in it though.
I'm thinking that Alice's problem is very similar, since everything was changed and something isn't set/adjusted right. It sounds like her truck was running fine until the rain came.
Alice, once you get it running again you may want to upgrade the point/condenser to a pertronix system. I did that with my Thunderbird, and never looked back.
__________________
Mike B
  #10 (permalink)
Old 01-16-2013, 09:55 AM
1971 Ford F-250
Yeah I don't know if I get the points it raining or not. But um yeah I've put so many parts into this said I'm kind of out of ideas. I really don't know if I miss gap points or if it's a bad coil or said something else going on. So I hope the mechanic can figure this out for me.
He's only charging me 25 to 30 dollars to undo the diagnostic. So that's not a bad price for diagnostic in yet. So I hope 125 total will be able to fix it. Because that's all I have left.
  #11 (permalink)
Old 01-16-2013, 12:44 PM
1971 Ford F-250
it cost me $20 to have it diagnosed and hes out grting parts. but what hapenend is the truck jumped timing
  #12 (permalink)
Old 01-16-2013, 01:03 PM
Gary Lewis's Avatar
FTE OK Chapter Ldr
So, he's going to pull the timing cover and replace the chain and sprockets? Hope so.
__________________
  #13 (permalink)
Old 01-16-2013, 01:14 PM
1971 Ford F-250
Yeah he's doing a forum timing chain gear is gaskets and all that so that will be good.
  #14 (permalink)
Old 01-16-2013, 01:29 PM
Gary Lewis's Avatar
FTE OK Chapter Ldr
Good. That would give you basically the same symptoms - fuel and fire but no run, although sometimes they'll backfire a bit. Anyway, good luck. let us know how it goes.
__________________
  #15 (permalink)
Old 01-16-2013, 07:53 PM
1971 Ford F-250
turns out when i bought it had no coolant in it and i over heated it. it welded the rings to the pistons. so i need a new 360 now :P
god i feel dumb for assuming coolant in the engine.
Alice
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
