door hinges
Old 01-14-2013, 10:22 PM
fordka's Avatar
fordka
fordka is offline
door hinges
are door hinges the smae for pas and dside or is there any difference if so how do you tell cause i need some but the set i had i mixed them up.
Old 01-15-2013, 03:14 AM
ncranchero's Avatar
ncranchero
ncranchero is offline
E9TZ-1522800-A Front Door Hinge
(Front Door Lower); RH and LH
E8TZ-1522810-A Front Door Hinge
(Front Door Upper); LH
E8TZ-22811-A Front Door Hinge
(Front Door Upper); RH
Old 01-15-2013, 07:30 AM
ArdWrknTrk's Avatar
ArdWrknTrk
ArdWrknTrk is offline
pedant
My upper hinges are stamped 'RS' & 'LS', but they are OEM replacements.
Not sure if they come off the line that way.
Old 01-16-2013, 10:20 PM
fordka's Avatar
fordka
fordka is offline
i looked at mine. the lower had no numbers are marks but i guess there both the same. the upper one had RS stamped on. the other LS. so i figure one meant right toher left looked at them more there marked the opposite but there were no other marked numbers or anything.
Old 01-19-2013, 09:08 PM
fordka's Avatar
fordka
fordka is offline
now that i got these figured out what is a good way to get these lined up because i am way off. i only cn bolt tthe bottom hinge to the door and it is way way off and i already accidently cut my door wires for the locks now i gotta fix that and i dont want to keep taking on and off the door.
Old 01-20-2013, 07:42 AM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
There are 4 different hinges
L upper (has the "spring" to hold the door open)
L lower
R upper (has the "spring" to hold the door open)
R lower
As for adjusting. SUNG the bolts up, NOT tighten them. Just enough to support the weight of the door, but still allow you to move it.
Then GENTLY close the door, looking for contact with the fender, rocker, cab etc. the move the door accordingly. Once you get it where you want it, Tighten the bolts
Old 01-20-2013, 07:59 AM
fordka's Avatar
fordka
fordka is offline
Would you do you get to the 3 bolts the hold the hing on. I dont think i can fit a wrench or ratchet back there
Old 01-20-2013, 11:24 AM
fdude64's Avatar
fdude64
fdude64 is offline
take the two out of the door and remove it, then you can get to the three that hold the hinge to the body
Old 01-20-2013, 11:26 AM
fordka's Avatar
fordka
fordka is offline
Ya exactly but onece i unbolt the door again since im by myself the hinges will get all off centered again tho
Old 01-20-2013, 11:38 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
It isn't easy by yourself.
I use a floor jack to hold the door up at the right height while i wiggle it around to get all the bolts started.
Old 01-20-2013, 11:41 AM
fordka's Avatar
fordka
fordka is offline
I actualy gave that way an attemt yesterday instead used a rim but the ground wasnt even ill put a piece of plywood down and see how she goes again. Thanks
Old 01-20-2013, 11:43 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
It's a balancing act for sure, but at least you don't have to try and hold the weight of the door while you're lining it up.
Old 01-20-2013, 11:44 AM
fordka's Avatar
fordka
fordka is offline
Oh ya. That is a pain. Tried it and dropped the door like 6 times and sliced some of the door wiring. Lucky i didnt break the windows.
Old 01-20-2013, 01:41 PM
fdude64's Avatar
fdude64
fdude64 is offline
I use my engine hoist to hold it up, lets you move it around as needed and also keeps the weight off you
Old 01-20-2013, 08:16 PM
Diesel_Brad
That works as well as a ratchet strap and a garage door track
Quick Reply: door hinges
