Will a 429 Cobra Jet engine bolt to a 75 f250 4 speed? - Ford Truck Enthusiasts Forums
Old 01-14-2013, 06:48 PM
cbelville47 cbelville47 is offline
cbelville47 is starting off with a positive reputation.
I have a 429 Cobra Jet engine. I was wondering if it would bolt up to the original 4 speed transmission in a 75 highboy 4x4?
Old 01-14-2013, 07:31 PM
J ballan's Avatar
J ballan J ballan is offline
J ballan has a good reputation on FTE.J ballan has a good reputation on FTE.
I'm pretty sure the 429 shares the bellhousing bolt pattern as 460s, 351m,351c,and 400 all of which were not an option for a 75 4x4.
Old 01-14-2013, 07:40 PM
J ballan's Avatar
By the way welcome
Old 01-14-2013, 08:49 PM
hasteranger's Avatar
hasteranger hasteranger is offline
hasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud of
number dummy is gonna come along and tell you no 429/460 4wd manual transmissions in the 70's... its a difficult one to piece together if youre trying to make it work. 429 is very similar to the 460. may want to try a search for 460 4 speed and read what others have tried.
Old 01-14-2013, 08:53 PM
1975MudRat's Avatar
1975MudRat 1975MudRat is offline
1975MudRat has a spectacular reputation.1975MudRat has a spectacular reputation.1975MudRat has a spectacular reputation.1975MudRat has a spectacular reputation.1975MudRat has a spectacular reputation.1975MudRat has a spectacular reputation.1975MudRat has a spectacular reputation.1975MudRat has a spectacular reputation.1975MudRat has a spectacular reputation.1975MudRat has a spectacular reputation.1975MudRat has a spectacular reputation.
Welcome! The 429 shares the "Big Block" Bellhousing. It will adapt to the 351M - 460. With the exception of the 360, 390, 427, and 428. These use the FE Bellhousing.
Old 01-14-2013, 09:00 PM
armstrongfordtrucks armstrongfordtrucks is online now
armstrongfordtrucks is gaining momentum as a positive member of FTE.
All you have to do is get a bell from a 400, it will bolt to your tranny.
Old 01-14-2013, 09:13 PM
the bell might, but what about flywheel, clutch, pressure plate, and starter? thats where it seems that most people have problems.
Old 01-14-2013, 09:15 PM
1975MudRat's Avatar
They should be the same because the 429 and the 460 share the same block. To my understanding.
Old 01-14-2013, 09:27 PM
390 flywheel
Old 01-15-2013, 06:29 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by hasteranger View Post
NumberDummy is gonna come along and tell you no 429/460 4WD manual transmissions in the 70's.
It's a difficult one to piece together if you're trying to make it work. 429 is very similar to the 460. May want to try a search for 460 4 speed and read what others have tried.
429 w/Ford 4 speed top loader: 1969 Galaxie/LTD/Mercury Marquis/Police Cruiser 429 4V / 1969/71 Mustang/Cougar/Fairlane/Torino/Comet 429 CJ & S/CJ.
429: 1968/71 Thunderbird, 1968/73 misc Ford/Merc Passenger Cars. Not installed in F100/350's.
All 1968/82 460's came with a C6. 460's not available with 4WD or M/T until 1983. All 1983/97 460 F250/350's came w/a hydraulic clutch.
460: 1968/78 Lincoln/Continental Marks / 1972/76 Thunderbird / 1973/78 misc Ford/Merc Passenger Cars // 1973/76 F100 / 1973/79 F250/350 / 1975/79 F150 / 1975/97 E250/350 / 1983/97 F250/350.
1979: TWO different 460 engines: Mid-year 1979 460 block casting number: D9TE-6015-AB = Uses a weighted spacer, the flywheel (flexplate) and harmonic balancer are specific to this casting number.
D1VE-6015-AB block casting number used 1971/73 429, 1971/78 460 and some 1979 460's. Does not have a weghted spacer.
D9TE: This was a "running change" that occurred in 1979, so there are no before/from specific serial numbers/production dates. The block casting must be known to get correct parts.
429 cobra jet for 600 bucks? crestfallinman Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 24 03-04-2016 07:28 AM
Cobra Jet intake on stock 460? Kirbys73F100 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 21 03-31-2014 07:18 AM
Ford 428 Cobra Jet Engine Block & Cylinder Heads BroncoDually FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 19 11-10-2010 04:10 PM
429 cobra jet heads on 460? YoungFordAddict66 1973 - 1979 F-100 & Larger F-Series Trucks 2 12-22-2008 10:39 PM
429 identification burton Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 23 08-27-2002 06:47 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
