bronco 302 transmission options - Ford Truck Enthusiasts Forums
Old 01-14-2013, 04:47 PM
mightymoose95's Avatar
mightymoose95 mightymoose95 is offline
mightymoose95 is starting off with a positive reputation.
hey guys so recently i have been doing a big project on my 93 5.0 bronco. when i first started i thought it was a head gasket but it turns out i had a nice big chunk taken out of one of my pistons. so i have decided to either rebuild it or buy a new engine. i have found one for sale that is a 302 out of a 72 torino that somebody put a 88 lower intake on to convert it to fuel injection. so i though of buying it but then i realized that theres no way my automatic E40D is gonna bolt to this engine. is there any kind of converter kit for this? any help is much appreciated! i miss driving the old bronco around and wanna get her back on the road ASAP!
Old 01-14-2013, 07:25 PM
Encho's Avatar
Encho Encho is offline
The Southernmost Mod
Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.
You will only run into issue after issue if you go down this route. Just find a proper Windsor 302 or 351 and everything else should be smooth sailing.
Old 01-14-2013, 07:56 PM
Conanski's Avatar
Conanski Conanski is offline
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
Quote:
What makes you think that? The trans bolt pattern has never changed on these engines so any year will bolt right up. What you will have problems with are the cam because it's not EFI friendly and the heads because they don't have the hardened valve seats needed for unleaded gas.
Old 01-14-2013, 08:54 PM
yea thats what i wanted to know is if it will bolt up. but i didnt think about the valve seats and how old they are. cause the heads are off a 69 truck
Old 01-15-2013, 12:53 AM
greystreak92's Avatar
greystreak92 greystreak92 is offline
greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.
As Paul said, the cam is not SD/EFI friendly AND those heads won't have hardened valves for unleaded fuel unless they have been redone with said hardened valves. Your E4OD needs the ECM for your fuel-injected engine to operate properly but the cam in that engine won't support an EFI swap. By the time you make that engine capable of going into your truck, you could probably find a more readily adapted one and ultimately spend less time and money doing it.
Old 01-18-2013, 12:48 PM
ok, ok you guys persuaded me! anyways i have another question. i found a 5.0 from a 88 f150 that i am going to get for it. he said it comes with the computer for it. should i use the one he gives me or can i just hook the big wiring harness to my same computer from my 93? also will my tourqe converter bolt on to the flexplate of that engine?
Stall converter for a C6... Pkupman82 Clutch, Transmission, Differential, Axle & Transfer Case 3 01-29-2017 08:30 AM
302 vs 351 build Deadsquiggles Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 106 09-03-2014 03:26 PM
Pilot bearing removal fordka 1987 - 1996 F150 & Larger F-Series Trucks 12 06-08-2014 04:04 PM
Another 351m/C6 to 460!! JB78f150 1973 - 1979 F-100 & Larger F-Series Trucks 10 01-24-2012 10:51 AM
AOD Converter drain Cfdchf Clutch, Transmission, Differential, Axle & Transfer Case 1 01-19-2006 05:32 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
