04 Ranger Spark Plugs - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 01-14-2013, 03:23 PM
blake in spokane blake in spokane is offline
blake in spokane is starting off with a positive reputation.
2004, 4L, sohc - Is there any issues or problems changing spark plugs?
Old 01-14-2013, 06:22 PM
f5fordgirl f5fordgirl is offline
f5fordgirl is starting off with a positive reputation.
We changed plugs in my cousins 04, had to remove the front wheels to get at them, took about 2 hrs, but didn't have any stripped holes.
Old 01-14-2013, 06:23 PM
pawpaw pawpaw is online now
pawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to behold
Some folks say its easier to remove the front wheels & inner fender splash shield & go at the plugs that way on the ohc 4.0L.
The specified finewire iridium enhanced center electrode with platinum pad ground/sidewire plug design is recommended, along with Motorcraft plug wires, as they're of good quality & designed to take the double work load & limit spark gap erosion our waste spark ignition system puts on them.
Be sure to check plug gap with a wire gauge, but ease up on spark gap & don't forcefully pull the gauge through the gap, so as not to damage the finewire center electrode, or sidewire platinum pad. Properly gapped these plugs will spark at a lower voltage, which helps on cold starts. I get noticeably faster year round starts with them.
Seeing as how spark gap is always opening up, consider setting plug gap at the min side of spec, that way spark gap will stay in spec longer & the closer gap will aid cold starts some & advance spark timing a bit & all that can help on really cold start mornings, when the battery voltage is at its lowest & is struggeling to run the starter to crank the engine, run the fuel pump & make a hot spark to get us going.
I also use a dab of high temp nickel Permatex anti-sieze on the plug threads & torque them to the low side of spec, to allow for the anti-sieze lube effect & not over tighten them.
I also butter on some Permatex silicone grease inside the plug & coil pack wire boots & onto the plugs external creamic insulator, to help prevent flashover on those wet dewey morning starts, or wet rainy days & prevent the boots from sticking/baking onto the plugs ceramics over time.
Some thoughts for consideration, let us know how it goes.
Old 01-14-2013, 08:57 PM
reddog99 reddog99 is offline
reddog99 is starting off with a positive reputation.
Besides what others have said, set aside an excess amount of time. The plugs in the 4.0L can be a real PITA to get at, especially the right-rear where the A/C - heater stuff is located. Expect to need tools you don't have, and to come away with bloody hands, getting into tight spaces. A tool to extract the plug cap from the plugs is a necessity. When you choose the tool, keep in mind that several of the plugs won't have room to get a straight pull on the cap.
You'll finish the experience with an extra appreciation for the 100,000 mile change interval. Other than that, no problem!
Old 01-14-2013, 10:55 PM
Thanks, To you that replied, I love all forums.
Why proper Spark Plug selection is so critical 96_4wdr Aerostar 1 02-15-2014 07:41 PM
e3 spark plugs TexasLonghorn75 2004 - 2008 F150 3 11-26-2013 01:18 AM
E3 spark plugs? deanjet Expedition & Navigator 6 03-09-2010 08:28 AM
Bosch Spark Plugs??? jason86 1997 - 2003 F150 31 10-30-2007 07:02 PM
Spark plug gap rudy84 1999 to 2016 Super Duty 3 03-11-2004 01:54 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
