Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > International Region > Australia Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Australia Chapter Join Chapter , Leader: ChunderDownUnder
  #1 (permalink)
Old 01-14-2013, 07:34 AM
4x4falcon's Avatar
4x4falcon 4x4falcon is offline
1986 Ford F-100
4x4falcon is starting off with a positive reputation.
Dry Vinyl Tape
Does anyone know of a supplier for dry vinyl tape in Australia?
I can get it from the manufacturer in the states but only in box lots (20mm tape, 160 x 30m rolls in a box).
I really don't need 160 rolls. 2 - 3 would probably do what I need.
__________________
Ross
Effii Gets Rebuilt
  #2 (permalink)
Old 01-14-2013, 05:20 PM
BigF350 BigF350 is offline
2000 Ford F-350
My Garage
BigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputation
adrian.erks.harris adrianerksharris
fleabay perhaps?
  #3 (permalink)
Old 01-14-2013, 06:50 PM
4x4falcon's Avatar
1986 Ford F-100
Tried there.
Only from the states.
__________________
Ross
Effii Gets Rebuilt
  #4 (permalink)
Old 01-15-2013, 05:04 AM
SSSimon SSSimon is offline
2005 Ford F-250
SSSimon is gaining momentum as a positive member of FTE.SSSimon is gaining momentum as a positive member of FTE.
What's it used for?
Maybe you can become the Aussie supplier care of 1 bulk order from the US and selling off the surplus via ozzy-fleabay.
I tend to use the rubber self-bonding 'dry' tape for lots of odd sealing jobs on the truck and around the house.
__________________
Mods done: lots of cheap mods (Hutch, IC boots, plenum inserts, IH uppies, HPx, AIH delete, EBPV delete, hi flow outlet, CCV mod, OCR, Superchips, Zoodad, 6637, 4" TB exhaust, JW valvebody, coolant filter, FRx, '05 HD lights with switch bypass relays, B100 ready fuel system)
Mods NOT done: big oil, big brakes, big turbo
Next mods: ? tuner, G2WW (on the shelf), alloy diff covers
Australia: where Mechanics use spanners and Plumbers use wrenches...
  #5 (permalink)
Old 01-15-2013, 06:44 AM
4x4falcon's Avatar
1986 Ford F-100
Quote:
Originally Posted by SSSimon View Post
What's it used for?
Wiring harness. Works up to 125C without breaking down.
No thanks. Been there, tried that. It's good when you have something new that everyone want's but as soon as others see you doing well with it then someone else comes along and sells the same or similar for half the price. Then someone else sells them for 1/4 the price. Soon it becomes pointless as the cost is more than the time is worth doing it.
Source for this? Is it good for high temp.
I've got silicone rescue tape but given that it's about $1 a meter it's way too expensive to use for wiring loom.
__________________
Ross
Effii Gets Rebuilt
  #6 (permalink)
Old 01-15-2013, 07:00 AM
4x4falcon's Avatar
1986 Ford F-100
Quote:
Actually found it.
Similar pricing to rescue tape.
The dry vinyl is about 5c per meter and it's what Ford and other manufacturers use.
__________________
Ross
Effii Gets Rebuilt
  #7 (permalink)
Old 01-16-2013, 03:51 AM
2005 Ford F-250
I got 2 rolls through a TV ariel installer. He said they buy it by the box load and use a roll of tape per install.
__________________
  #8 (permalink)
Old 01-16-2013, 06:42 AM
4x4falcon's Avatar
1986 Ford F-100
Available here:
Self Amalgamating Tape
That's about the cheapest I've seen it.
I bought mine in Kmart Karratha when they had a sale on. $10 per 5m roll.
__________________
Ross
Effii Gets Rebuilt
  #9 (permalink)
Old 01-17-2013, 04:55 AM
2005 Ford F-250
Only suggestion I have is to use the self-amalgamating tape but NOT to form a continous loom. Just bind the wires at every junction then every 10cm or so, then encase in the black plastic split loom.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
