Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > International Region > Australia Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Australia Chapter Join Chapter , Leader: ChunderDownUnder
  #1 (permalink)
Old 01-14-2013, 04:43 AM
SSSimon SSSimon is offline
2005 Ford F-250
SSSimon is gaining momentum as a positive member of FTE.SSSimon is gaining momentum as a positive member of FTE.
How much boost will pop a head gasket?
Lots of the common mods on my engine, but stock HPOP and injectors.
Pulling up Clyde Mtn yesterday I was getting over 29 psi of boost from the stock turbo with stock compressor wheel.
Next mod is going to the new Gen 2 WW which could increase the boost to as high as 43 psi.
Should I be worried about blowing a head gasket at that boost level?
I sort of thought I'd be safe with the stock HPOP & sticks...
__________________
Mods done: lots of cheap mods (Hutch, IC boots, plenum inserts, IH uppies, HPx, AIH delete, EBPV delete, hi flow outlet, CCV mod, OCR, Superchips, Zoodad, 6637, 4" TB exhaust, JW valvebody, coolant filter, FRx, '05 HD lights with switch bypass relays, B100 ready fuel system)
Mods NOT done: big oil, big brakes, big turbo
Next mods: ? tuner, G2WW (on the shelf), alloy diff covers
Australia: where Mechanics use spanners and Plumbers use wrenches...
  #2 (permalink)
Old 01-14-2013, 05:21 AM
ChunderDownUnder's Avatar
ChunderDownUnder ChunderDownUnder is offline
Garage is empty, add now
ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.
Boost is boost, whether you have big sticks or not. What I would be more concerned about is back pressure until you get ya wheel. The main advantage of the wheel is back pressure is kept in check on the stock turbo. In regards to HG's or studs - when you up or above 40psi.
__________________
Brian
03 F250 XLT LB . Full Engine build with all the goodies. Tuned by Matt
- cant wait until my motor blows so I can blame someone else -
join the Australian Chapter here-Join Chapter
  #3 (permalink)
Old 01-15-2013, 04:26 AM
2005 Ford F-250
I know my turbo is getting 'surge' at high (for stock) boost - I can hear the fluttering/pulsating noise - it sounds a bit like a cheap ricer blow-off valve - but continuous pulsing.
The G2 WW should solve that problem - the explanation I saw was that the surge is a cavitation issue on the inlet side wheel rather than back pressure affecting the exhaust side of the turbo.
Anyway, the shiny new G2WW arrived today. Out of respect for Diesel Site no pics or comments until I've run it past them.
__________________
  #4 (permalink)
Old 01-16-2013, 12:38 AM
You are right in relation to the surge. But you should realise that BP will cause more damage to your engine, than surge in relation to your turbo. Pushin 30psi out of a stock blower will give you BP. The cool thing about that wheel is you can get 40psi out of it with out increasing turbine speed and the all important BP is kept well in check for that kind of PSI.
SOOOO for little expense you get ya surge sorted, you can achieve 40psi out of a GTP38 and you win on BP.
__________________
Brian
  #5 (permalink)
Old 01-16-2013, 03:22 AM
2005 Ford F-250
OK, is there any tell tale signs that I should be watching out for regarding engine-threatening levels of BP?
I was sort of figuring that I had any BP issues avoided with the 4" TB exhaust I now have and the fact that I will never be pushing anything like 500+ HP out of my set up (hence to qualification of stock HPOP & injectors).
But I would prefer NOT to learn about it the HARD WAY THIS TIME !
40 psi out of a stock blower for a $200 WW upgrade is a lot cheaper that a GTP38 - but not if the result is a BP issue leading to an engine failure !
I have been thinking of the BP as the pressure in the exhast AFTER the tubo. But the engine damaging BP would be pressure in the headers and up-pipes BEFORE the turbo. I can see if this pressure got too great the exhaust gases wouldn't get out of the cylinders quick enough and pressure would build inside the engine and blow a head gasket or worse.
Given the inlet and exhaust turbines are running at the same speed, is the exhast BP BEFORE the turbo roughly the same as the boost pressure?
If the Gen2 WW will achieve 43 psi then maybe I NEED to be getting the HD headstuds now!
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
