idol problem - Ford Truck Enthusiasts Forums
idol problem
Old 01-13-2013, 09:52 PM
rameyme rameyme is offline
rameyme is starting off with a positive reputation.
idol problem
i have a 1990 f150 5.8 when it idols down after start it will idol down and amost die then up it will do this a few min then die anybody have any idea why
Old 01-13-2013, 10:52 PM
timbersteel's Avatar
timbersteel timbersteel is online now
timbersteel has a good reputation on FTE.timbersteel has a good reputation on FTE.
May try to clean the IAC valve located on the throttle body. Unplug the sensor connector. Remove the 2 screws attaching it, careful not to damage the gasket if possible. Clean well with brake cleaner or electronic cleaner and be sure to keep the solenoid part dry and free from any chemical.
Old 01-14-2013, 07:52 AM
Freightrain's Avatar
Freightrain Freightrain is offline
Shiftoholic
Freightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to behold
Welcome to the forums.
Yup, I'd check into the IAC first. If they get cruddy, they will get sticky and not work smoothly. Thus your idle will surge.
Old 01-14-2013, 10:12 AM
garrett_8 garrett_8 is offline
garrett_8 is starting off with a positive reputation.
Billy IDOL is not a problem
idle on the other hand
Old 01-14-2013, 11:36 AM
thanks guys i think that fixed the problem
rough idol sometimes SBFD8 1999 - 2003 7.3L Power Stroke Diesel 6 12-04-2016 08:40 PM
Problems after a medium burn-out. Kyre Searcher 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 25 07-29-2016 05:30 PM
Rough idol 2011 f250 6.2 gas LFPENN1974 1999 to 2016 Super Duty 5 06-21-2016 10:20 AM
Weird exhaust noise when cold Crewcab Turbo 1999 - 2003 7.3L Power Stroke Diesel 7 12-12-2011 08:05 AM
Engine load FordMan35 6.0L Power Stroke Diesel 7 04-13-2011 09:28 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
