You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Got a 2012 f250, it has air bags in the rear so it raised the back slightly otherwise stock. Can I fit 35s on stock suspension or do I need a leveling kit or a small lift?
I had a 2011 f250 6.2 (moved to a 12 psd now) I have run 325/65/18s on both trucks. Those tires are 35" tall and probably about 12" wide. They fit fine but I would get a little rub on the on the passenger side when the wheels were turned all the way to the right.
On the gasser I trimmed the plastic wheel well a little and fixed it on the new 6.7 I installed a 2" leveling kit and it fixed it.
Hope that helps
I have these on my truck, and they fit fine with no rubbing at all, even at full lock with the suspension articulated in either direction. I have no lift added, but the front end does have the snow plow prep package, so the springs may make it sit a little bit higher.
__________________
2011 F250 R/C Long Bed 4x4 6.2L Tuxedo-Black, Husky Mud Flaps, Dual Mode Reverse/Auxiliary Flood Lights, Air Horn
Custom Side Exit True Dual Exhaust(Think Lightning)
Tuned by *****5 Star Tuning***** Coil On Plug Info Re: Modular Ford Engines
Those tires are a Load Range D, not E. Also with a Max of 50 psi, doesn't your TPMS go off? You are losing 600lbs per tire of payload allowed. Plus they are only 34.7" too, not really 35's. I was looking at the Duratrac's in 305-70-18 and found out they would rub at full turn so I opted for the stock size as I did not want a lift.
__________________
Kevin
2011 F-250 CC, 6.2 Gas, 3.73, 4x4 w/FX4, Tuxedo Black, Steel Cloth interior,Goodyear Wrangler Duratrac's, Air Aid Intake, Bilstein 5100 shocks, Hellwig adjustable sway bar, 5 Star Tuned, Line X bed liner, X Tang Tri-Fold bed cover.
Correct, they are only D's, they do not offer an E' and I have yet to tow heavy enough to need the extra payload- which is a 220 to 550 pound loss per tire, depending on model. Either way, I am still above the rear GAWR which is 6100 lbs(3195lbs per tire x 2 = 6390 lbs). The TPMS- yep it's been on the whole time, I got used to it. As for the 34.7", the tires actually measured 35 7/8" inches when new, quite a bit more than what they say they are. As long as I keep them properly inflated, and tow within the manufacturers ratings, they will be just fine. I do not know why you heard the 305-70-18's would rub, that is only 34.8" tall, and narrower by almost a half inch than what I am running, so it definitely would not rub
at all. And again, I checked mine at full lock in both directions with the frame articulated on steep bank.
__________________
