Towing Capacity of the 2012 F-250 6.7L?
If you are internet shopping, try and Google "RAM 5500 Long Hauler" and check that thing out. Kinda interesting. Turning radius is probably about the same as an aircraft carrier though...
All F-450 trucks are DRW. If you order a chassis cab then you will get the 19.5" wheels and much larger brakes. Don't get stuck on rotor size alone....caliper size and pad area are major factors. You can also order an additional midship tank with the chassis cab models for a very reasonable price.
It sounds to me like you should be looking at the chassis cab models since you can option it exactly like you want. If you purchase an aluminum hauler bed then you will save a lot of weight on the rear springs. You will need an air ride hitch at a minimum because the springs alone in a medium duty truck are too harsh for your fifth wheel pin box. Another option is an air ride pin box or even a Kelderman type rear suspension on the truck.
The current F-450 pickup trucks are really a F-350 Tow Boss package...it is not the same as a chassis cab truck. Try not to get caught up with the HP/TQ ratings between the two models....they are measured in a completely different way with different duty cycles. The F-450 chassis cab will handle that trailer with ease. Happy towing with whatever you choose.
2012 F-450 4.5 Door Super Duty Conversion
All you have to do is ask your dealer to put you in contact with a body builder (outfitter) in your area. They will purchase the incomplete vehicle and finish it how you like. You can specify the Kelderman suspension or something similar. Check out Stock Height | Kelderman and then click on the side bar link for "Medium Duty" and go from there. They have some cool stuff.
If you browse around the net you will find dozens of body builders who specialize in RV hauler bodies. The fully aluminum bodies are premium units and nicely styled. I kinda wish I had one of those since my steel body is pretty heavy. My F-450 weighs about 11,000 lbs without the trailer.
Just make sure the builder is licensed by Ford so your warranty will be in full effect. Many builders are licensed so it shouldnt be too hard to find.
JSpurgeon
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
13
07-24-2011 07:06 PM
