fuel sending unit
The sending unit can only "go in" one way. Impossible to install 'upside down' as it's composed of a crooked arm the float attaches to and the fuel pickup tube.
also i seen a blackburn splice reducer,so i can extend the crooked float arm on my sending unit for the 38gallon tank.boy ill never be able to afford to fill this tank.
dear,numberdummy if you look at lmc website you'll find a 38gallon REPLACEMENT tank.this is why i'm having the problem,but thank u so much you have been helpful on all my posts.
Electrical connector on top with siphon tube and float pointing rear wards.
Normally with the 38 gallon tank it should read full until it reaches 19 gallons and then the gauge will behave like normal.
If the connector is attached and yet reading empty uou either have a defective sending unit or the wire somehow broke.
Grounding the sending unit wire to the frame should make the gauge peg full if the wire is good and the gauge is operating correctly..
Josh
Josh
Just take the sending unit wire and ground to the frame. If the gauge legs full then you know the gauge works and wiring is fine at the connector.
Then you can move on to troubleshooting the sending unit.
Josh
Josh
When you ask a question, it's your job to list all the pertinent info.
People aren't mind readers, so if you don't list what is pertinent, how would anyone know?
i'm getting to think you might be touched with a little alzheimer's,if you LOOK at the first post i put up,i said i pulled out a 38 GALLON. HELLO.also you counter dictate your self on another post i put up,so i don't want to be mean,but to save a argument don't reply to my post.THANK YOU.
Originally Posted by btracy
when i dropped the tank its the 38gallon.
You said your truck had a 38 gallon tank, but you failed to mention it's an aftermarket tank.
Since there were no 38 gallon tanks available from Ford, I assumed you were mistaken as to its capacity.
I'm 68 years old, with an IQ of 163, and a 90/95% memory retention, so I don't forget much.
And if I typed a question, I certainly would not forget to list all the pertinent info!
well,if ford didn't make then,its aftermarket,i didn't miss typo.i can get that your VERY knowledgeable about ford trucks,BUT most of us are back yard mech,that's why we need this web site.so yes we are going to miss some info,but since your so knowledgeable,i would think you can understand what the topic is about and not over analyze our computer skills.again sorry about being backlashing.
