Trouble CodeP0306
Trouble CodeP0306
My truck developed a misfire and this is the code that I pulled. It is a misfire on cylinder #6. I have replaced the spark plug and the coil pack. This did not fix the problem. I have been informed that the next step is to replace the ignition module. I have researched this and cannot find the ignition module in my Chilton Manual. The only thing that I can derive from the manual is that on this year of Ford F150 is that the ignition module is incorporated into the PCM. My question is would the ignition module be the next step in this process and if so do I have to replace the entire PCM?
GammaDriver
07-08-2002 08:51 PM
