Knock Sensors and the 3.0L
Hey saint,
What you say is a start, and seems to support the "no knock sensor" proposition. I also heard that the sensors were "discontinued" on the Vulcan sometime in the mid 90s, which is consistent with what you found regarding the lack of knock sensor DTCs after '94.
Also, I just looked at Haynes for my '97 Taurus (3.0L Vulcan) and it specifically references the knock sensor as being used only on the OHC Duretec.
If it turns out to be true....no knock sensor on mid 90s+ Vulcans... then I have to wonder why the heck that would be? Especially with all the talk you hear about pinging in the Vulcan.
Hi Ken,
Just to add a little more.....The PCM will advance the timing to the
point of pinging, then back it off (retard) it a little. This is a constant, dynamic thing. With this kind of system, you will actually
pick up some performance by using a higher octane fuel. Most
of the European manufacturers (Saab, Volvo, VW, etc.) with
turbochargers have this type of system....In addition to timing,
the knock sensor will also determine the amount of boost
pressure.
pressure.
Bob and Ken, glad to have you guys join the discussion! What you said about knock sensors and the way they work with the computer to combat pinging is good stuff.
Although its aimed little more toward high performance engines, here is a good article on the subject: Knock Retard
Also, here is a nice little 2 page PDF Article on knock sensors and what they do. Contains a few neat sketches and graphs, too: Knock Sensors
The question still remains in my head....why wouldn't Ford use knock sensors on the current generation of Vulcans which are known to ping?
Hey Rock,
Maybe they figured out how hard it was to get rid of the ping before we did. LOL. "Hey guys this pinging keeps messing up the knock sensor......" I can see he engineers grinning from here. LOL
Hey Ken and Bob thanks for the insight. Always glad to have expert opinions.
Knowing how Ford does things I'd bet they got rid of the knock sensors to save money. With a little different programming of the PCM such as more EGR flow, less timing etc they are able to keep it from pinging without the extra sensor. The newer engine controls are more accurate than the older ones. With more accurate MAF readings etc they are better able to manage the fuel and timing curves.
Been looking in to this for a while. With 9.3:1 compression, the Vulcan leads the pack in compression ratio for Ford OHV engines. There hasn't been a ratio that high in years. I think that is the main issue.
Couple that with the 14lb injector thing and we are bound to ping.
The '94 ECU has an unused pin 23 labeled KS in the Ford Diagrams. Yep, Knock Sensor. My guess, it pinged regularly, they could not get it to run in the prescribed timing (for smog/efficiency), so they dropped the sensor (which the ECU sees as "all's well, keep the full timing!"). I would like to add the sensor and get it going. The 8.0"1 compression supercharged engine I'm building would love it.
My Supercharger page
bartlettf150
05-22-2015 09:10 AM
PropEng
1983 - 2012 Ranger & B-Series
01-21-2014 02:36 PM
