HELP!! Where to put strobe bulbs in reverse lights f250 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 01-10-2013, 09:36 PM
Big.blue0586 Big.blue0586 is offline
Big.blue0586 is starting off with a positive reputation.
What's up guys I have a 2005 f250 I recently purchased strobes 2 amber and 2 white I plan on putting the ambers in the reverse lights and the clears in the tails but when I took the light out and looked in the reverse section it looked too tight.... I know it can be done, seen plenty of videos just wondering before I drill the holes and find out its too late, where the best spot in the reverse light would be to drill the hole I have the m looking strobe bulbs. The side of the reverse housing looks the best but the strobe bulb and the reverse bulb looks like it will hit ........ Please help thanks guys
Old 01-10-2013, 10:57 PM
Layson's Avatar
Layson Layson is offline
Layson has a great reputation on FTE.Layson has a great reputation on FTE.Layson has a great reputation on FTE.Layson has a great reputation on FTE.Layson has a great reputation on FTE.
I have mine in the reverse light housing. It is a real tight fit.
Old 01-10-2013, 11:01 PM
Did you put it in from the side or bottom?
Old 01-10-2013, 11:25 PM
Layson's Avatar
I think it was to the side. It is tight. I do remember breaking a strobe bulb due to it touching the reverse bulb.
Old 01-13-2013, 06:19 PM
SoFla David's Avatar
SoFla David SoFla David is offline
SoFla David is starting off with a positive reputation.
I swapped my reverse light bulbs to a different bulb with a smaller glass dome to make more room for the strobe tube. They are not as bright as the original bulbs, but they solve the problem.
Old 01-15-2013, 06:17 PM
Great idea thanks sofla david
Old 01-15-2013, 08:03 PM
pbeering's Avatar
pbeering pbeering is offline
pbeering is gaining momentum as a positive member of FTE.pbeering is gaining momentum as a positive member of FTE.
You can also put the clears behind the reflector blank or in the stop/turn lamp assembly where there is far more room.
Old 01-15-2013, 10:00 PM
Yahiko's Avatar
Yahiko Yahiko is online now
Yahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputation
Once you get it done please share some photos of the work and maybe a video
of them in action.
Sean
Old 01-15-2013, 10:52 PM
6.2gasser's Avatar
6.2gasser 6.2gasser is offline
6.2gasser is starting off with a positive reputation.
I installed Whelen vertex hide-away LED strobes in my tail lights. Yes, the clear I installed in the reverse light housing was very, very tight! The red I installed in the red brake light housing wasn't near as tight. One of the reasons I went with LED's is because they are smaller than the tubes, same diameter but not as tall, and it is still difficult to find a spot to mount. Oh, and I have a 2012 super Duty so I guess the tail lights haven't changed much.
Old 01-16-2013, 08:32 AM
tjc transport's Avatar
tjc transport tjc transport is offline
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
i replaced the reverse light bulbs with amber strobe tubes, and mounted remote reverse lights that actually light up behind the truck.
Recommendations for Strobe Setup? ColoradoF350 1999 to 2016 Super Duty 19 12-17-2015 10:47 PM
Started installing strobes in 2011 superduty Jammin1 1999 to 2016 Super Duty 12 08-08-2013 02:15 PM
Cab Light Strobes Rose Clifford 1987 - 1996 F150 & Larger F-Series Trucks 11 12-09-2011 07:00 AM
2011 - Hidden Grill LED Strobes DrewF 6.7L Power Stroke Diesel 17 09-28-2011 07:16 AM
F-150 Crew Cab Strobe Install Help AngeloCosma 2004 - 2008 F150 15 08-12-2008 03:19 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
